Thread: pool water clear but comes out of return grey
    my pool water is clear but when it comes out the return its grey. I have an above ground pool 15x30 with a cartridge filter. It also come out grey when i vacuum the pool.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pool water is clear but comes out of filter return cloud
    Quote Originally Posted by rnocella72
    rnocella72,
    Please start a new post and read this: http://www.troublefreepool.com/pool-...efore_you_post
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pool water clear but comes out of return grey
    Welcome to TFP!
    Do you have a saltwater chlorine generator?
    no i dont....2 hp pump just repaired,impeller no good...still blowing grayish water out of return....pool is slightly cloudy....i was told i added to much algecide because its also foamy...
    22,548
    Most likely the algaecide causing it.
    30,419
    It seems to me that if your pool water is clear but comes out of the return gray then there must be something wrong with the filter. Have you checked it? That's the only reason for "grey" to be added to your pool that I can think of.
