Results 1 to 7 of 7
Thread: am i crazy?
    am i crazy?
    I am presently running my pool pump motor (DYNA GLAS MPRAGE 147L) 24hours/7days in order to keep algae growth to a minimum, due to the continuous heat.
    Am I placing my motor in jeopardy by doing this?
    27ft Above Ground Pool
    Sand filter
    Re: am i crazy?
    That isn't a problem for the pump, only for your electric bill.
    Running the pump extra won't help prevent algae unless you have a SWG, tablet feeder, or bleach pump that only runs when the pump is on. The thing which prevents algae is maintaining an appropriate FC level for your CYA level.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: am i crazy?
    Only reason I'm running my pump like a madman is to keep the aerator coolin' down the pool a bit.
    Re: am i crazy?
    thank you(s) for replies.
    i'm not sure what FC level & CYA level mean. can someone explain?
    i am using a tablet chlorine feeder.
    Sand filter
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: am i crazy?
    Rita,
    You'll want to start here. Reading Pool School should give a bit of insight into the things talked about on this message board.
    FC = Free Chlorine, and that is the stuff used to keep your pool sanitized.
    CYA = Cyanuric Acid also referred to as stabilizer or conditioner. This is what helps protect the chlorine from 'burning off' in direct sunlight. Too little and most of your chlorine can be lost in about 30 minutes of direct sun. Too much and it interferes with your chlorine's ability to sanitizer and kill algae.
    (Pulled from Definitions and Abbreviations in Pool School)
    It's also best if you were to own your own test kit so you know exactly what your pool is doing.
    There are a few recommended, but most on the site use the TF-100.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    SW Georgia
    300
    Re: am i crazy?
    ditto to what Westsidepool said.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: am i crazy?
    Hi Rita,
    I just looked at your other thread, some of these recommendations have been suggested to you but it doesn't look like you investigated into it any deeper than adding a bunch of ph up.
    Do you want to take control of your pool and make it simple? Read pool school, tell us about your test kit, and post your test results.
    The kind members here have inserted the links to the pages that you need to read, and given you information about how to get a test kit that will help us help you, if you want the help. ^^^^^ look up^^^^^^
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
