Thread: Controlling a 2 speed pump
    Apr 2011
    Toledo, OH
    71
    How are others controlling their 2 speed pumps if you want to split the time between low and high speed?
    The man on top of the mountain didn't fall there.
    24' x 52" Intex ultra frame pool (12,400 gallons) with seperate Intex 2500gph pump and SWG and 2 Intex magnetic pool lights.
    Looking to upgrade to 27-30' semi inground install
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Controlling a 2 speed pump
    There are three ways to control a 2 speed pump:
    Manual switch
    Two speed timer
    Controller
    I use a controller which has separate timer functions for high and low speed. The next best thing would be a two speed timer.
    Mark
    For simple setups a manual switch works just fine. You normally leave it on low all the time unless you are backwashing, vacuuming, or coating the grids of a DE filter.
    Apr 2011
    Toledo, OH
    71
    I'm guessing the switch would be on the back of the motor? What would be good reasonable priced 2 speed timer? If I don't need one that would be great, but I thought in the 100s of posts I've read here that you needed to run hi speed a little a day for a skimmer to work properly.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    As long as you can get enough flow through the skimmer on low speed, you shouldn't need to run on high speed. I only have a manual switch, and I get good flow through both skimmers with the pump on low speed and the main drain valve 1/4 of the way open.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by guamguy
    That is pretty key but it also depends on if you have an automatic cleaner and the size of 2 speed pump.
    Mark
