Day 1
Just started conversion last night, added about 6 gallons of bleach to pool; generated interesting clouds of mustard-yellow WOW!!!! Believe all I need to do at this time is to keep adding bleach to keep FC at 15ppm. Have purchased Taylor K-2006 test kit and tested for first time this morning. Only added 1 drop of R-0871 FAS-DPD Titrating Reagent to 10ml sample to get color change from pink to clear. I interpret that ppm FC level = 0.5ppm, is that correct? If I had to add 2 drops FC level would = 1ppm? So fo getting a reading of 15 ppm FC one would have to add 30 drops to 10ml sample? Did use Jason's pool calculator to come up with about 6 gallons of bleach to get to 15ppm FC. Also added another 6 gallons of bleach this morning and am off to store to buy more... Photos from this morning below!
Many thanks for any help - Barb
