Thread: Plumbing pump to cartridge filter help
    Hi. I just purchased a jandy cl 580 filter to replace my Hayward s220t sand filter which I thought was just too small. I have a sta-rite 1 HP dura-glas pump.
    My question is how to plumb the pump to the inlet of the cartridge filter. The inlet is only 10" off the ground whereas the pump exit with an elbow would have to be at least 16" high.
    Would you advise to raise the filter ~6" off the pad with some pavers or bricks or plumb it by adding 2 extra 90 degree elbows. Connections will be 2" PVC.
    36k in ground pool
    1hp sta-rite pump
    Jandy CL580 cartridge filter
    Most plumbing 1 1/2" PVC
    36000 IGP Roman shaped Sta Rite dura glas 1HP pump
    Jandy CL 580 cartridge filter Lrz Gas Heater (pilot light)
    Polaris 380 with 3/4 Booster Automatic Vinyl Pool Cover.
    Tri-Chlor pucks in skimmer
    Advantage Pool Vac (1.5 HP pump with 150sqft cartridge filter on dolly)
    22,553
    Re: Plumbing pump to cartridge filter help
    I would add the extra plumbing to get it to the pump. I don't like raising it up unless you can build something pretty substantial.
    ____
    Thanks, I might try to use 2 45 deg fittings instead of 2 90's. __/ |
    Seems like a poor design decision by Jandy to make the inlet so low as I don't think there are any pumps out there with an outflow that low.
    22,553
    There are several models of horizontal discharge pumps and even one that allows you to easily change between vertical and horizontal. But I know that's not helping your situation.
    It doesn't really matter if your use 45's or 90's the head loss is about the same.
