Thread: "good" readings but still slight green color
    18 foot diameter pool with "good" readings but still have a slight green color and water not 100% clear.
    FC = 6
    CC = 0
    TA =120
    CYA = 55
    PH 7.2
    What next??
    Jun 2010
    Glendale, CA
    513
    Re: "good" readings but still slight green color
    Give us a little more info. How long has the water been in the pool? What was the source of the water (well/city) Was there an algae issue before?
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Also, what kind of pool do you have? is is a salt pool? Inground, AGP? Vinyl, Gunite?
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Feb 2008
    Denton, TX
    5,061
    Please do the overnight FC loss test. Once the sun is down, check your FC and record the value. Then, in the morning, before any sunlight hits the water, check your FC again. If your FC has gone down more than 1 ppm overnight, you need to shock your pool.
