Results 1 to 15 of 15
Thread: Anyone use CYA from Walmart?
    Gulf Coast, AL
    61
    I looked at the label and it states 100% cyanuric acid.
    The price was $11.99 for 3 lbs.
    My pool stores sell 99% for $17 to $20 for 4 lbs.
    Anyone use the walmart brand?
    16x32 Grecian, vinyl liner, IG, 19000 gal.
    1.5 h.p. Hayward Super Pump 2 speed. Hayward S244T sand filter
    Circupool RJ45 SWG, TF100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Anyone use CYA from Walmart?
    I haven't, but plenty of other posters have, and swear by it.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    It has worked fine for me so far.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2009
    Shawnee, Kansas
    92
    I have used it for two years with no issues.
    Matt
    20,000 gallon, sand filter, IG vinyl
    Butterfly's Avatar
    South Carolina
    10,045
    As they said, we have had lots of good reports about it. Good price and more powdery which allows it to dissolve faster.
    You're done SLAMing when:
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I use it every year. Seems to work fine. And if you put it in a sock in front of your skimmer and squish it, it seems to disolve pretty fast.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Mar 2011
    Lower Bucks County,PA
    65
    Have been with no problem's but it was impossible to find this year . Four walmart's within 10 miles, nothing. Ended up at pool store(argh) $25 for 3.5lbs!! Went early in season and was told all chem orders were finished ? Ya think the pool store could have at least bought me diner first before they screwed me. Next year i'm buying online, between the gas and final cost , live and learn.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Aug 2010
    Central Illinois
    49
    Same here with the walmarts out of stock. I bought some at ace hardware.
    DIY 18x36 Vinyl Liner 1Hp 2 speed super pump, Hayward Swim Clear cartridge filter, Pentair 12v Intellibrite 5G, MX8 suction pool cleaner.
    I used HTH stabilizer at a friends pool, then had to get more and got that from the pool store, not sure of the brand but directions said to lower pH to something like 7.2, then add to the skimmer. The HTH dissolved easily in a stocking on the pool. The other did not. It seemed harder baked and bigger chunks. Couldn't dump in the skimmer since the filter was due to be cleaned, so we used the stocking again. Took quite awhile. Anyhow, that its my report on the comparison.
    Jan 2010
    Randleman,NC
    620
    no problem..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Apr 2011
    Lynchburg VA
    393
    I get mine from Lowe's, no problems! Sure beats being pool stored!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Couple of notes....it only says to lower the PH to 7.2 just to make sure you get the PH in line (whatever your target) before moving on the CYA.
    Also--regardless of skimmer vs sock method, you shouldn't clean or backwash for a week.
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Gulf Coast, AL
    61
    Thanks for the replies.
    I'm going to give it a try.
    It's too bad they do not sell it in larger containers though.
    I'm constantly having to add it because of all the rain we get.
    Good thing is.... it's cheap.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by chriscard25
    The "no cleaning or backwashing" is for when you add it to the skimmer because it takes so long to dissolve and the granules will fall out of the filter undissolved. There's no reason not to clean the filter if it's added via sock. No different than cleaning the filter any other day.
    I think it's important to clarify this because those who are shocking will NEED to clean their filters regularly during the process. A very good reason not to use the skimmer method to add CYA if you think you'll need to shock within a week or are already doing so.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Meijers Sells the HTH Stabilizer in 4lbs for $14.99 I believe.
    I've been using it for the past 2 years w/ no issues.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
