Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Intex 2100 Sand Filter
    Okay. I finally got my Intex sand filter setup after a sand nightmare.
    One of the local pool stores sold me "Filter sand" or at least they said it was. It wasn't marked on the bag anywhere and i ended up taking their word for it.
    So I basically ended up with ~10lbs of sand in the pool.
    Basically my I am just concerned. I have the filter running and I have seen some videos of people with the 2100 and 2650 sand filters on their pools and you can see the flow very strong on the top of the pool. On my pool I don't see much flow on the surface even with the nozzle aimed up to the surface.
    I am wondering if there is some reason my pump isn't pumping much or if its fine and I'm just paranoid.
    Filter Pressure is half way in the green mark ~5psi. - Both plunger valves are open and locked and none of the inlets/outlets are clogged as far as i can tell.
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Intex 2100 Sand Filter
    Welcome to TFP!
    The 2100 and the 2650 is the same pump. 2100 is min flow and 2650 is max flow.
    How much sand did you put in the filter?
    I know the filter actually holds less sand than what it says it holds. Try backwashing the filter until the water is clean coming out of the back wash port. You may see sand coming out and that is ok. Once the water is clear you should be good to go. After the backwash make sure you run the filter on rinse for a few seconds to settle the sand back down in the filter.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    I put it just above the half-way mark between min-max.
    And i did about 2 minutes of backwashing and realize i need a longer hose so i dont flood my yard when i do that again....
    I did the rinse also for a couple of seconds.
    I hooked the skimmer basket back up to the intake and while the output back into the pool doesnt show much more flow than before, the skimmer is pulling a LOT more water in now than it used to.
    I guess I am just being paranoid, it just seems like a lot less flow than some of the youtube videos i have seen.
    [youtube:1pl8tww9]wX9vv0ExMFE[/youtube:1pl8tww9]
    Video of the pool with filter on
    And also I have Aqua Quartz #20 Pool Filter Sand
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    i would think that the water would be flowing alot stronger than that video shows with that pump. the sand may not work in that filter. someone else can probably offer further advice.
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    crookm11's Avatar
    Jun 2010
    422
    The flow with your pump is not right. Could you post some pictures or video that shows how you have everything hooked up? What is the pressure reading when the filter is running? Post a picture of the pressure reading to if possible.
    Mark Crook
    Ok here are the two pictures.
    I also put a video up of the flow just going straight into the pool, not through the plunger valve.
    I have tried to run it in recirculate to bypass the filter to see if that was the problem with no difference. I unplugged the skimmer to check that also and nothing seems to change it.
    http://www.youtube.com/watch?v=9RKMQjg7ivY
    Oh and ignore the water on the ground. The drain cap came cracked so the drain leaks a bit (waiting on a replacement cap)
    crookm11's Avatar
    Jun 2010
    422
    From what I can see in the pictures everything is hooked up correctly.
    Are you talking about the drain cap on the bottom of the filter?
    When you run the pump does water spray out of the cap?
    Does the water coming out of the return go thru the entire return fitting or just thru the center movable ball?
    Mark Crook
    The drain cap on the pool is cracked not the filter.
    and the water comes out of the center ball and a little bit around the sides.
    crookm11's Avatar
    Jun 2010
    422
    When you take the return cover off of the fitting are there clear rubber/plastic flaps on the inside of the return? If their is not any there then that could be the reason you have no pressure coming out of the return.
    Mark Crook
    Yea, the clear parts are there, but only cover roughly half of the holes on the outer part.
    Also is it normal for the plunger on the return to shake? it kind of vibrates around when the pump is on
    crookm11's Avatar
    Jun 2010
    422
    I'm not sure about the plunger valve vibrating except that it may just be loose.
    The next thing I would try is take the plunger valve off of the pool and connect the hose directly to the pool fitting. Do this on the suction side also. This will help eliminate any possible restrictions you may have. The valves and hoses are a little restricting so now I think is is just trial and error.
    Mark Crook
    Tried that and still didnt change it at all.
    Going to try to bypass the 6 way valve and just go straight from Pool -> pump -> pool, and if its still weak there it might be something wrong with the pump.
    Ok I bypassed the 6-way and just went straight through and there was little/no improvement in flow, so either its doing as much as its supposed to or something is wrong in the pump.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    has to be something wrong with the pump. probably the multi port valve. sorry to hear it. can you take it back where you bought it?
    Talked to Intex this afternoon, the lady I talked with said it had a 2yr warranty.
    But she said that I should give it a few days to see if it gets better or worsens.
    And if it worsens just call back and she will open a claim and send me a new motor once i fax receipt.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Quote Originally Posted by OsiViper
    good news! let us know how it turns out.
    Well yesterday morning the pump just stopped pumping.. the motor was spinning buthehere was no flow. I checked all the valves and checked for a clog but nothing there. I looked in pump with it running. The looks like the impeller became detached from the motor.
    Called Intex and told them and they sent out a replacement pump that same day and told me to keep the broken one for parts if I need them.
    So far I am really impressed with Intex's customer support.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    hey, thats great news! once you get one that works properly you will see the difference!
  20. Back To Top    #20
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hello folks,
    I don't know if I should create a new post for this or not, but I have a question about the 2100 pump. My wife is out of town and picking up the Intex 2100 GPH sand filter pump. From what I read in this post, this is the same as the 2650 pump? I was under the impression that the 2650 was a new, upgraded pump. If not, is it a 2-speed pump? Thanks in advance for any advice.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
