Results 1 to 15 of 15
Thread: what problems come from low Total Alkalinity? Any?
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    I posted this question because i could not find a answer on the Board
    I've been told by TFP not to worry about low Total Alkalinity
    On the WWW it says otherwise can some set me straight on this?
    this is what i found :
    PROBLEMS RESULTING FROM LOW ALKALINITY: If the Alkalinity of your pool is too low, these problems will occur:
    * Dissolved metallic parts of your pool (walls, floor, hand rails, ladders, light fixtures, and equipment). This could even lead to discolored water or stains on the pool walls and floor.
    * Stained and etched concrete in concrete pools.
    * Stained and etched plaster in gunite or shotcrete pools.
    * Stained liner in vinyl-liner pools.
    * Blistering or delamination of fiberglass in fiberglass pools.
    * "pH Bounce." Alkalinity acts as a buffer for pH. If the Alkalinity is low, the pH will fluctuate dramatically. Yesterday, it may have been 7.0, and today it may be 7.8, and tomorrow it may be 6.8-it can change from one extreme to the next, literally overnight.
    * Minimizes the effectiveness of chlorine (or its alternative).
    * Eye and skin irritation.
    Thanks
    Pasted from <http://www.poolmanual.com/manual/alkalinity.html>
    5,593 gallons of water at 80% capacity <Orlando, Florida>
    AG Intex Round Metal pole Swimming Pool - 16 Feet x 48 Inches (Intex A 16 X 48 F B02 11 01)
    Sand, SandPro 75 – 3/4 HP, 45GPM/2700GPH flow rate. GAM-4511 (Just days old 7/5/11)
    Crystal Clear Still
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: what problems come from low Total Alkalinity? Any?
    Quote Originally Posted by 20GT
    Nobody here told you not to worry about low TA. It can cause pH instability.
    Butterfly's Avatar
    South Carolina
    10,045
    If we did say not to worry about your TA, then your #'s were within acceptable range.
    Did you see Recommended Levels in Pool School?
    You're done SLAMing when:
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    Hmmm please review my post (Link) on the second page i ask "do i need to care about phosphates, calcium hardness, total alkalinity."
    http://www.troublefreepool.com/test-...t35565-20.html
    Crystal Clear Still
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    Ah found it thanks
    vinyl with Bleach
    FC 3-7
    pH 7.5-7.8
    TA 70-90+
    CH 50-300
    CYA 30-50
    Crystal Clear Still
    Right, your TA is just a little high, nothing to worry about since you don't have a SWG.
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    pinch a penny wants you to keep it between 120-140 lol
    Crystal Clear Still
    Butterfly's Avatar
    South Carolina
    10,045
    Ah found it thanks
    vinyl with Bleach
    FC 3-7
    pH 7.5-7.8
    TA 70-90+
    CH 50-300
    CYA 30-50
    And here are/were your #'s:
    FC = 10 ,TC = 10 ,pH = 7.4 ,TA = 110 ,CH = 160 ,CYA = 50 (7-10-11)
    So your TA is okay, a touch high (definitely not low) and if the pH remains stable it is fine where it is, your CH is just fine, and phosphates in a properly chlorinated pool don't matter. ie, JasonLion's pool is over 4,000 (I think that's close to correct) & he has no problems.
    We/I saw where the pool store tried to pool store your wife (in that link) and we just tried to clear it up for you.
    It is not a good idea to put your test numbers in your sig. The sig is for mostly permanent information.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, if you were using trichlor tablets you would want your TA to be higher, around 100 to 120.
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    thanks
    and we are using those
    (just updated sig will remove it after a while) 7-12-11
    Crystal Clear Still
    That "don't worry" was in response to your post immediately above that reported TA 100 and CH 160. Both in range for vinyl.
    If you mean to ask if you should EVER worry about them, read Pool School.
    Mar 2011
    Orlando, FL
    12
    I would be more concerned at this point with the CYA at 100 and using pucks as you are still increasing it.
    pool-school/chlorine_cya_chart_shock
    Viking Pools Freeport 12' x 25' Fiberglass 6000 Gallon Screened - Hayward Pro-Grid Vertical D.E. Filter DE2420 Hayward Superpump 1HP - Zodiac Pacer Cleaner - Pool Pilot Digital - TF-100 test kit - Central Florida Thanks to TFP Pool School, SWCG and the Pool Calculator, taking care of the pool is easy!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by GK
    Yes, and here is the cross reference link: post293340.html#p293340
    Jul 2011
    Weddington, NC
    9
    San Juan Pools (fiberglass) says to keep TA between 125 and 150. Is that true for all fiberglass pools? Why that high?
    12,500 Gallon fiberglass, chlorine,1 skimmer, 2 returns adjustable eyes, sand filter, automatic chlorinator (don't use except for vacation or if CYA gets low), 1-1/2 hp EcoTech motor on Pentaire Supeflo pump some trees.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    No, here are the recommended levels for a fiberglass pool, Pool School - Recommended Levels
    Please start your own thread with new questions rather than asking your question in another thread.
