Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: How do you test for chlorine
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I'm wondering how you all do your routine chlorine testing. Does anyone use the fas-dpd almost exclusively?
    . . .OR
    Which method do you use for routine checks, DPD?
    . . . OR
    OTO?
    I really enjoy testing with my TF-50's fas-dpd test. I'm wondering in the long run if that will be wise economically.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Jul 2007
    Chicago, IL
    87
    Re: How do you test for chlorine
    I have a hard time telling the shades of yellow apart so like you, I almost exclusively use the fas-dpd test. More expensive I'm sure, but I'd rather know for sure where I'm at. Interestingly, I have no such problem with the ph test.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Jul 2007
    Suwanee, GA
    528
    I always use the dpd
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    FAS-DPD 2 or 3 times a week. I have to stare at the OTO test for quite a while to detect the shade, but I always do it first then run FAS-DPD to see how close I am. I'm getting better. I also tried with the DPD tester from an old Leslies kit, and I am much more accurate with that. I must be able to discern shades of pink better than shades of yellow.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    one drop of OTO into the pool.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by X-PertPool
    Since you're a pro, I figured you'd just scoop up a mouthful and swish it around.
    Mar 2009
    Charlotte, NC
    539
    That shade of yellow is difficult for me.
    I use the 2 part red shade daily, once a week or 10days I confirm w the FAS DPD
    The red is just so much more accurate for my eyes
    I get it at Leslies (unless I'm placing an order w our magnificent Duraleigh), Taylor R 0001 + R0002; it tests FC not TC, & you need that cell w the red on itnot the yellow OTO.
    I determined beyond a doubt that the chlorine savings FAR outweighed the 1part yellow OTO vs the 2 part red price difference.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Jun 2011
    Cape Girardeau, Mo
    125
    I exclusively use the fas-dpd test everyday .
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    OTO = daily test.
    FAS-DPD = weekly test.
    chiefwej
    Sep 2010
    SC Lowcountry
    54
    FAS DPD every other day
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Jul 2010
    Mickleton, NJ
    229
    Quote Originally Posted by Richard320
    Ok, that made me spit my coffee onto my laptop.
    I do both daily, I have a cya of 70 so I keep FC over 5 (usually 6-8 range) so I like that the DPD test is more accurate with higher levels of FC.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    30,426
    Ditto!
    I do OTO daily and FAS/DPD once weekly or so. Over the years, I have about learned just how much FC my pool uses so I find myself skipping the FAS/DPD test every now and then.
    (Refill customers...PLEASE pay no attention to the above statement...I was temporarily deranged)
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    fas dpd every other day, my pool numbers are pretty consistent so I add a certain volume of bleach on the "off" days and then test every second day, I find this reduces major drops in chlorine levels between tests. The tests usually come in at expected/consistent levels.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by chiefwej
    OTO = daily test.
    x2
    OTO to make certain pool is chlorinated and hasn't dropped drastically for some unexpected reason; FAS-DPD "roughly" every week or so when I want to know exactly how much chlorine I have, or in case of a pool party or if I changed pump run-times/swg percentage, etc.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    I've been keeping a log of my tests, for the most part I test 2-3 times weekly with DPD. If the weather changes then I will make sure to test.
    I'm sure both temperature and sunlight have an effect, does temp effect chlorine usage more than sunlight?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Only have the FAS-DPD test, so that is what I use. Probably every 2-3 days, unless there has been a change in the weather or bather load. Then it is every day.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Aug 2010
    Dallas, TX
    4,052
    DPD for routine checks. I find it pretty easy to tell right where I'm at, or at least close enough for government work. Maybe once a week with FAS-DPD, or when shocking (hoping I never have to do that again though!)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Funny thing, when I've been swimming around patching above ground pools in the past I could tell the customer "do you only use the tablets (tri-chlor) for your chlorine". They would usually say yes and I knew this because I would get some of the pool water in my mouth and the water would be so acidic from the tabs that it would make my mouth and teeth feel dry.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I am obsessive about chlorine and do the DPD daily. After reading this however, Im going to try a drop of OTO once in a while for fun.
    Essential Links:
  20. Back To Top    #20
    Aug 2010
    Boston, MA
    176
    FAS-DPD only, since I have 60 CYA. So if the OTO can read it, then it's below minimum.
    I don't see how the OTO is actually useful except for SWG or very low CYA.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
