Thread: best angles for jet eyeballs?
    We have two eyeball-type output jets in our IG pool. what are the best angles for these to get the most stuff into the skimmer (located on same side of pool as jets)? Thanks so much!
    In-ground pool owner in NW Georgia: 18 x 37 IG Grecian vinyl pool installed April 2011: 27k gallons, Hayward SWG auto-cleaner with booster pump, Hayward Aquarite T-15 Salt System with timer freeze controls, Hayward Aqua Plus, 1.5 HP Tri-Star pump, 48 sq. ft. D.E. filter.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: best angles for jet eyeballs?
    I like around 30 to 35 degrees off the water surface.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Every pool is different. You should perform your own experiments with your returns.
    Some pools have their returns located all around the pool and can move all of the water in a circular motion. Our old pool had only two returns, but they could move that water all around a 16 x 40 foot pool. Other pools have their returns on one end pointing towards the skimmers on the opposite end; the water flows across the pool.
    It is not necessary to have the returns pointed up in order to have the water, including the surface water, move in a desired direction. We keep our returns pointed flat out. The water surface doesn't get broken. One can watch as leaves fall into the pool: they travel all around the pool and then float into either of the two skimmers.
    Some people like having their returns pointed up to give a little bit of action to the water as a personal preference. I like that ours are flat out because it is easy to see every tiny spec of dirt either when vacuuming or when suffering from an attack of Chronic Sparklypoolitis, especially right after putting the vacuum away.
    We turn on a water feature when we need the pool to "look sparkly".
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Can you post a sketch of your layout? (it will help us optimize your circulation/ skimming action )
    Luv& Luk
    -Ted
