Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: What is this brownish dust at the bottom of my clear pool?
    Hi,
    I have this brown dust (it disintegrates when I brush it or just come close to it with a brush) that accumulates at the bottom of my pool only while the pump is running. If I vacumm at night, then shut the pool off, I will wake up the next morning and it's ok (no dust accumulation). However if I vacuum in the morning and run the filter all day, when I come home from work, it's all over the bottom again. Been going on since I opened the pool in May.
    Here are my latest readings using the TF-100 kit.
    FC 3.0
    TC 3.0
    TA 60
    CYA 45
    pH 7.7
    Could this be algae? My water is always crystal clear. It accumulates in any crevices and seams along the bottom only when the pump is running. I wonder if I need to change over the DE in my filter? Can't get rid of the stuff, whatever it is. In this picture you can see it at the edge of the walls and the bottom and it's scattered around the bottom. The dark spot in the upper right side of the picture is just the reflection of a tree.
    [attachment=0:wc56ja41]IMG_6588 (1283 x 855).jpg[/attachment:wc56ja41]
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: What is this brownish dust at the bottom of my clear poo
    Dirt (super fine), pollen, maybe some old dead algae. I gave up filtering and vac'd mine to waste to thin it out. Split it up 3 different times so far to minimize water loss at a shot. Still got some..................but it's thinned waaaaaaay down.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Yep, I'd say dust, pollen and such. I deal with it everyday, as I am surrounded buy plants and trees, road dust, etc. I just plop the vacuum in the pool everyday and let it do it's thing. I also use skimmer socks, you wouldn't believe the amount of pollen and bugs it catches. I know how you feel, looking at nice sparkily water and seing a dirt splotch on the bottom. My daughter thinks I have OCD over running the vac for the pool...lol
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    30,426
    I would try two things which may eliminate or minimize it....
    1. Up your FC level to about 6-8ppm for at least 4 days and see if that helps. If it's algae, the "dirt" will increase at first and then go away.
    2. Clean you filter. What is your normal psi? what is it now? when did you last recharge?
    I will raise the FC level as you suggest to see if there is any difference.
    My normal psi is about 11. It's running at about 13-14 now. i usually only change out the DE as it approaches 18-20 (usually once a season). I've been running with the same DE since I opened on May 8th.
    It doesn't really hurt anything to change it out now to see if there is a difference. Maybe I'll try that this weekend.
    Thanks for the ideas.
    Quote Originally Posted by pepsiholic
    I hear you. If I put the vacuum in, it is gone in seconds. Better yet, all I need to do is brush the bottom and it's gone. It only returns when the pump is running though. Probably due to the pump pushing the water into the deep end and the dirt/dust sinks there. Either that or it's coming from the filter. I may try cleaning the filter this weekend to see if it makes a difference (even though my psi is only 1-2 above startup).
    30,426
    There is discussion going on now about the suggested psi increase to indicate backwash is due. It looks like around 20-25% is about the maximum increase the forum would like to see so you would be at that right now.
    I would backwash the filter. Waiting for the psi to almost double restricts your flow excessively.
    You might try that first before adding the FC so, if one of them works, you can identify what the cure was.
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    Hey Dave,
    Can you point me to the discussion about the psi increase/backwash? I searched for it & can't find it. Just curious cause if mine gets 8 psi above, I hardly have any flow from the returns. Mine is usually about 4 above & flow is greatly diminished.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    Guest
    Run53 -
    I have the exact same problem! The "dust" only appears when the pump is on for a while. I'm kind of glad because that tells me that its not algae The filter bag on my Polaris 280 does not catch it, its just too fine a material. I am going to try vacuuming to waste and rigging socks on the returns to see if I can trap it and get rid of it... I was going to add DE to my sand, but seeing that others like you have the same problem even with DE filters it seems unlikely that adding DE will help me
    Here are some pics of my "dust":
    Diver's Avatar
    May 2011
    South of Boston
    450
    wkener2,
    this looks exactly like my steps. i'm pretty sure it's dust. i don't think that it really matters if pump is running or not - i think when pump is running it moves it around and it becomes more visible in the uneven spots.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Aug 2011
    Clovis, Ca
    31
    I just put a 'dust and silt' bag on my 280, it cleared my dirt and sand problem in two days. I might give that a shot as our pool was doing the same thing, I believe it was the dirt being deposited by the pumps.
    http://www.amazon.com/POLARIS-SAND-SILT ... B0006ZM4KS
    Brand new IG gunite and plaster approx 18,500 gallons measured at fill from H2O meter.
    Clean and Clear Plus Cartridge 420 CU.FT.
    IntelliFlo VS-3050 VS+SVRS Pump
    Polaris 280 Cleaner
    Intellitouch automation
    TF100 Test kit
    Guest
    mckay,
    I just ordered the filter bag you recommended Vacuuming to waste helped but some of the silt still comes back...
    Jul 2015
    Cromwell CT
    2
    Re: What is this brownish dust at the bottom of my clear pool?
    Hello, I just came across this posting as I've been dealing with this same issue for almost a year. I can not figure it out. Did you ever find the cause of this issue and if so, what was your resolution.
    May 2016
    Dordogne
    1
    Hello, I too what like to know if there was a definative answer please?
    Last year a spent every evening of the season cleaning fine dust from the bottom after the pump had been running, only to find it returned 3-4 hours later.
    At the end of the year I changed laterals, sand and pressure was nice and low and water clear.
    Just opened and run for a few hours and its back?
    Apr 2016
    Johnsonville, SC
    2
    What's the reason for this stuff on the bottom?
    I have been fighting what I thought was a algae problem all summer. I got suspiciouse about the stuff forming when I ran the pump and on purpose I didn't run the pump all day. When I got home after work... Nothing was on the bottom of the pool. It seams to be produced only when the pump is running.
    Any idea how to prevent this from happening?
    Jun 2017
    windsor
    1
    Hi, I've been getting this brown dust too! It only happens when my sand filter is running. I have a 18' above ground and just changed the sand and checked all the parts inside and everything is good. I've backwashed and rinsed a number of times and it's still happening!!! Chlorine levels are good and PH level is good. The water is crystal clear. I noticed though if I don't vacuum it up in a timely manner it will leave a yellow stain. Please help, it's driving me crazy!!
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Could be grackles dropping poo in the pool...I'm in a battle with a couple now.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Jun 2017
    Boston
    4
    Bumping an old thread. This EXACT same thing is happening to me! I've changed my sand, laterals, back washed, vacuumed to waste. You name it, I've tried it. This stuff keeps coming back. How did you guys solve this?!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I get this in my pool this time of year. It's pollen in my case.
    There is a huge red pine (neighbors tree) that is the bane
    of my pools existence. It overhangs the pool in the deep
    end and is dropping items year round.
    Needles then pine cones, then pollen nodules. I'll get
    a brief break from all that usually only for July & August,
    then it's dumping on it again. Wish i could cut it down.
    Dolphin E10 Cleaning Robot.
  20. Back To Top    #20
    In some cases, it's a rare type of mustard algae.
    Support the site
