Results 1 to 8 of 8
Thread: Help with numbers
    Help with numbers
    Pool is clear but...
    FC 5.5
    CC .5
    TC 6.0
    Ph 7.5
    TA 130
    CH 260
    CYA 40
    Salt 3500
    Pool calculator says not to add anything but I know I should add CYA but I don't know how much. Should I add anything else?
    Mandy
    20,000 gallon fiberglass inground pool * Hayward sand filter and pump * Jandy Aquapure 1400 SWG * Jandy Aqualink Control System
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Help with numbers
    Use a target of 70 for CYA and the calculator will tell you how much to add.
    Love TFP? Become a
    TFP Supporter!
    Thanks. I put in 70 for my cya goal with all my other numbers and it still says not to add anything.
    Mandy
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    if you list CYA as 40 as your current reading and 70 as your target, it should give you an amount to add based on the pool water volume you input at the top of the page
    Jul 2009
    Houston, Texas
    9,409
    I plugged your numbers into the pool calculator and it says you should add 80 ounces by weight or 83 ounces by volume of CYA to reach 70.
    Love TFP? Become a
    TFP Supporter!
    Maybe I'm not plugging my numbers into the correct box. I put my numbers in the first box on the left and then hit calculate. Should I do something differently?
    Thanks.
    Mandy
    Butterfly's Avatar
    South Carolina
    10,045
    Do you have your pool size of 20000 gallons in the top of the calculator?
    Then, CYA, enter 40 in the NOW column and 70 in the TARGET column. Then hit calculate.
    You're done SLAMing when:
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    You put the numbers you currently have in the first box and the numbers you want in the second box. So, your CYA first box woudl be 40 and second box would be 70.
    Also, in the bottom box of the first group, if you will list your chlorine source as a SWG and the type of pool you have, it will give suggested levels above most of the box. With TroubleFreePool.com settings, SWG + Fiberglass = CYA of 70-80. You do have to now manually put 70 in the right hand box though - it does not change that automatically for you.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
