Results 1 to 11 of 11
Thread: What about chlorine gas?
    Jun 2011
    las vegas nv
    7
    I searched here for something on this topic and came up empty. Is that a good way to chlorinate and are there pool service companies out there that use the chlorine gas? Any downsides?
    Inground plaster 20,000 gal
    Whisperflo 2hp pump
    Feb 2008
    Denton, TX
    5,061
    Re: What about chlorine gas?
    Not too much here on chlorine gas as TFP is mainly a consumer learning forum and chlorine gas systems are typically reserved for large, commercial pool operations.
    22,550
    For a pool your size I recommend liquid injection. It's easy to do.
    Is there any particular reason you want gas?
    Jun 2011
    las vegas nv
    7
    No.... just exploring all options. I see you all are big on the BBB method and thats cool, but i travel a lot and can only service my pool once a week or so. So bottom line I wont be able to add a little bleach every night. I asked about cal-hypo in another thread and that got shot down pretty quickly. [calcium hardness]
    Whisperflo 2hp pump
    South Central NJ
    3,192
    Cl gas requires a number of safety precautions. Most towns won't let you do it except under very controlled conditions that would not be economically reasonable for a residential pool. Cl gas is highly toxic. Imagine what an accidental leak from a full bottle would do.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2011
    Brookeland, Texas
    89
    I'm certainly not one of the experts here, and some one please correct me if I am wrong, but I believe it is worth mentioning here that a SWG is producing Cl gas.
    12k gal. Free form 14' x 28' IG gunite, 8' raised spa, Hayward T15 SWG, Hayward Ecostar VS pump, Hayward Super II pump, Booster pump, Polaris 280, Hayward DE 7220 filter, 400k Btu heater, Color logic LED lights. Pro Logic controller with remote.
    Oct 2010
    Georgia
    317
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    With a SWG the chlorine gas never leaves the SWG cell. With conventional chlorine gas you have a chlorine gas tank, which can leak. Chlorine gas has gotten less popular with commercial pools over the years because chlorine gas leaks can kill people while liquid chlorine leaks are a mess but don't generally kill people.
    michael89156, a SWG, or Liquidator, or bleach pump will all meet your requirements for less money and far more safely than a chlorine gas system.
    22,550
    I only add bleach about once a month or less. I load a 15 gallon drum with bleach and the inject it with a pump.
    Jun 2011
    las vegas nv
    7
    Some good suggestions guys, thanks.
    Whisperflo 2hp pump
    Dec 2009
    Europe
    89
    If you can only visit your pool once a week why not consider a dosing pump with a large container filled with Bleach/chlorine in. You can then set up the pump to dose small amounts direct into the return pipe whilst the pumps are running. It is a method I have been using on many pools for some time now and believe it or not your chlorine requirement with be approximately half that if you were to manually dose so it won't take too long for the dosing pump to pay for itself.
    100,000 litre pool used to be manually dosed daily with 10 litres of 15% Chlorine... Same time of year but with dosing pump the pool now requires 5 litres per day and the FC level stays around 5 - 8 PPM all day long dependant upon bather load.
