Results 1 to 16 of 16
Thread: Device to measure muriatic acid
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Just wondering what you all use to measure muriatic acid before adding it to pool. Hate to pour it in a container that melts through.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Device to measure muriatic acid
    [center:2znbsasp]http://www.lesliespool.com/Home/Pool-Chemicals/Chlorine/14491.html
    [/center:2znbsasp]
    May 2011
    Woodslee, Ontario Canada
    26
    Personally, I just guesstimate, since we're talking about thousands of gallons of water. As I read here before, not making rocket fuel. On old plastic measuring cup would work fine since it's only gonna be in it for a minute at a time.
    14X28 inground Vinyl
    1HP Super II Pump
    200lb Sand filter
    Tri-chlor, bleach shock
    BBB
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Quote Originally Posted by Richard320
    [center:13tzqtj0]http://www.lesliespool.com/Home/Pool-Chemicals/Chlorine/14491.html
    [/center:13tzqtj0]
    You really love that cup Richard.
    10,800 gallons
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    It comes in a plastic jug and I pour it into a plastic measuring container and rinse when done.
    Mar 2010
    Spring, TX
    1,082
    I used a small plastic container I picked up at walmart. It measure up to 64 oz in increments of 8
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2011
    Grand Rapids, Michigan
    279
    Funny that this came up just now. I had never dealt with MA before and had to add some today. Had some extra plastic cups (new, unused) so I marked a 1 cup spot on it and used that. And if I remember right it was Richard who said he pours his MA into a bucket of pool water & then dumps it all in the pool. I liked that idea so that's how I did it. Thanks, Richard! (You made it not so scarey to deal with)
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Richard320's Avatar
    Jan 2010
    19,058
    Quote Originally Posted by Whatrymes
    [center:1mecupjb]http://www.lesliespool.com/Home/Pool-Chemicals/Chlorine/14491.html
    [/center:1mecupjb]
    I guess so....it just works so well. The only drawback is the size, shape, and handle. I use that cup to hold my sample water while testing, too. There have been some close calls from leaving it too close to my coffee mug.
    Adding acid is a little bit tricky and a little bit dangerous.
    When doing so, I wear eye protection and heavy black rubber gloves, both available at your local hardware store.
    Remember also from chem class: always add acid to water, never water to acid (it spatters).
    I fill a pail 1/2 way, measure the acid into a plastic measuring cup, slowly pour it into the pail to dilute it some, then pour the pail slowly into the pool. Rinse the measuring cup and pail, and done.
    In-ground, 13,000 gallon pool, plaster, built 2008-9.
    Pump Whisper-flow 60 gpm DE filter
    Spa: 2013 Hot Springs/salt generator
    I use a cup like Richard's.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I use a red disposable dixie cup, the hard plastic type. I've marked it on the out side at 1 cup and 2 cups. It's close enough. I've been using the same cup for a month or so. When I have to replace the cup it won't be a loss. The other good thing is I don't have to worry about it getting lost or used in the house.
    Aug 2007
    near the swamp
    806
    Quote Originally Posted by threewide
    This. I just put the jug down into the water, then pour it out.
    Jun 2007
    New Jersey
    653
    I go by Taylor Acid Demand, and in my pool, one drop equals 1/3 of a gallon. I just stand upwind and pour it in gently split among my three returns from about a foot off the water. I just guess at how much has gone in. Been doing it that way for thirty years and never a problem. Maybe a whiff every now and then.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Recycle and reuse
    I use a 32oz gatorade bottle. I measured and marked 16oz, 24oz, and then full is 32oz. I have one bottle for muriatic acid, and another for 12.5 Liquid Chlorine.
    It works very well.
    ___________________________________________
    20x38 Kidney IG vinyl, Intelliflow VS pump, Cart Filt.
    Jul 2007
    Suwanee, GA
    528
    Like the clown above, I use a Solo plastic disposable cup. I've been on the same cup for over a year now. I'll pour the acid into the cup while holding both over the pool, then dump the acid in with the cup close to the surface and then rinse the cup in the pool. I may be living on the edge, but I wear no protective gear when adding the acid.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Apr 2011
    Murrieta, CA
    2,360
    The clown tries to stand up wind and wears sunglasses, it's better than no protection. LOL...
