Thread: cya testing black dot
    On taylor test kit, Instructions say add solution till black dot just disappears. does that mean it is completly gone or just starts to fade from complete circle.
    Mar 2010
    Spring, TX
    1,082
    Re: cya testing black dot
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    The black dot should be completely gone, no hint it was ever there even if you stare at it for several seconds.
    is this the accepted method for testing for cya or are there other methods available.
    14000 gal swg pool
    gunite plaster pentair swg
    30,431
    It is virtually the only realistic one....it's what everyone uses
    There are other methods, all of the affordable ones are worse than the black dot test.
