Thread: sand filters
    Jun 2011
    Lake Country GA
    6
    sand filters
    We replaced the sand in filter today ...and now the box is reading no flow..Any suggestions?
    16x32, vinyl liner, sand filter, salt, 22,000gal. GA
    22,553
    Re: sand filters
    Give us more info. That's not a lot to go on.
    What is the box?
    Why did you replace the sand?
    What is the flow like out of the return?
    Jun 2011
    Lake Country GA
    6
    Re: sand filters
    Finally figured it out...someone had a senior moment...and decided to check something & didn't have it turned
    right...the box is the one that gives you all the readings...salt water system...we changed the sand because
    it had never been changed (not an easy job)...this pool has been wonderful until this year...just about everything
    has had to be replaced...the other thing is my pump gauge is still reading 30...that is a little higher than in past.
    Is this normal?
    22,553
    Re: sand filters
    Thanks for the update.
    Does the gauge go to zero when you shut the pump off?
    Jun 2011
    Lake Country GA
    6
    Re: sand filters
    You know I really haven't paid attention to that I will check it tonight when I cut it off. Next thing is one of
    the automatic timers quit working...the one that turns the pool on & off...the polaris timer is still working..
    Gee this will be like a new pool when we are finally done...
