Thread: Speaker Wire Size
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    Speaker Wire Size
    When hooking up your outdoor speakers, what size wire did you run and what was the total length. My longest run will be about 50 feet and was wondering if 16 gauge would be sufficient or is a 12 or 14 gauge more appropriate?
    Greenhaw
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Speaker Wire Size
    If your using large size or top end speakers then run 12 gauge to get the clarity and base response they are capable of. If you are using 'average' speakers then 16 gauge should be fine.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Speaker Wire: Choosing and Installing
    http://www.crutchfield.com/learn/learni ... ml?g=22100:
    Jandy 2 speed pump
    Green1340's Avatar
    May 2011
    55
    I am leaning toward 4 of the TIC GS5 Omni speakers. Maybe a couple of the Yamaha wall mounted on the cabana. I don't intend to go real hi-fi, just want some music around the pool. Maybe I just split the difference and use the 14G; that should handle the 50' runs without a problem.
    Greenhaw
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    I went 12AWG for all runs from 50 to 140 feet. Overkill, yes, but the cost difference was manageable and I only wanted to run them once,
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
