Results 1 to 8 of 8
Thread: Latest Numbers. Thoughts or suggestions?
    CL-5
    BR-10
    pH-7.5
    TA-70
    FC-7
    CC-0.5
    CYA-80
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    22,539
    Re: Latest Numbers. Thoughts or suggestions?
    [s:1mi1p3bs]Your FC should never get below 6 ppm and should be held between 6 and 9 ppm all the time.[/s:1mi1p3bs]
    Sorry I see that you have a swcg.
    You don't need to include a BR number unless you have a bromine pool. Did you get the Cl number using the FAS-DPD or the OTO kit? You should report chlorine as either FC, CC, or TC.
    I got the cl number from the k-1000 kit that came with the tf-100. It's the best I could guess. I have a hard time telling the difference between those shades of yellow.
    22,539
    I assume you got the FC & CC numbers from the FAS-DPD kit. If so, there's no use even running the OTO test. The OTO kit tests for TC.
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Quote Originally Posted by Butterfly
    Several times. Just wanted a few opinions from some seasoned pros.
    Butterfly's Avatar
    South Carolina
    10,045
    Those numbers look great
    What is the CH? Just to make sure it is not too high.
    Butterfly's Avatar
    South Carolina
    10,045
    About that OTO test, trying to read the yellow color is kinda difficult for lots of us.
    It is, however, a bullet-proof test to prove that you have chlorine in your pool.
