Thread: skimmer filter
    skimmer filter
    what causes skimmer basket to crack several times a year? could it be my pump being too big? my pump is 1.5 h.p. the baskets break along the top rim everytime.
    24 ft. 52 in. deep above ground
    hayward sand filter
    new pool owner/new bbb believer
    Feb 2008
    Denton, TX
    5,061
    Re: skimmer filter
    It is probably due to it becoming obstructed with debris and there not being a path for the water flow around it. You probably need to just clean it more often or turn the flow down on the skimmer(s) a bit.
    Aug 2010
    Dallas, TX
    4,052
    Re: skimmer filter
    Do you put chlorine pucks in your skimmer?
    Re: skimmer filter
    i use liquid bleach in pool. how do i turn down flow on skimmer?
    hayward sand filter
