Thread: Re-hanging a door...need some help
    Apr 2010
    Buckeye, AZ 85326
    619
    I know there are a lot of DIY'ers here so I figured I'd give this question a shot.
    I removed a door to fix the weather stripping on the bottom as it was falling off. When I put the door back on it didn't really seem to line up. The reaveal on the hinge side at the bottom is pretty much non existent. So I'm looking for some help as to getting the reaveal equal as it should be and to get the door to shut properly. It has self closing hinges at the top and bottom and a regular hindge in the middle. The door worked perfectly before I started messing with it.
    Thanks for your help.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Mar 2010
    Spring, TX
    1,082
    Re: Re-hanging a door...need some help
    If you have not posted here
    http://www.doityourself.com/forum/
    Try that site. A lot of helpful info.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
