Thread: intex vs hayward
    intex vs hayward
    i currently have the intex 2100 sand filter but a friend has given me a hayward 1 hp sand filter.
    it's the pro flow lx series. would i be better off keeping the intex system on or changing out
    easy set 18x48 intex 2100 sand filter or hayward sand filter w/1 hp pump
    Oct 2010
    Georgia
    317
    Re: intex vs hayward
    The intex 2100 is a .95 hp pump with a 100 lb sand filter which has a flow rate of 2100 gallons per hour or 35 gallons per minute.
    The Hayward 1 hp power flow LX series is a pump. What is the size or model number of the filter?
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    the filter is s166t15425
    the multiport is sp714T1
    Oct 2010
    Georgia
    317
    Looks like they are comparable in size and flow rate.
    Hayward s166t is a 1.4 sq ft filter. It will also hold 100 lbs of sand. The flow rate is 35 gallons per minute.
    Both filters should yield comparable filtration.
    I perceive the Hayward pump and filter to be of better construction than the Intex, but have no data to support that perception other than the higher price.
    PSG
    poolschoolgrad
