Thread: How do you clean a pool filter?
    Jul 2010
    Ashland, KY
    21
    How do you chemically clean a pool filter? What is the best way to change the sand?
    Hayward Pro Series 300 lb s224T Sand filter
    25K Vinyl In ground, 1 1/2 hp Hayward Super pump, Hayward Pro Series 300 lb s224T Sand filter, Hayward H150 Gas heater. Aqua bot Turbo Cleaner FC 2-3, Cya 10, PH 7.4, TA 60, CH 30
    Aug 2010
    Dallas, TX
    4,052
    Re: How do you clean a pool filter?
    Is there a specific reason you need to change the sand? There is typically no reason to do any more than backflush, so I'm curious to know what you want to solve.
    Various chemical cleaners are sold, but they are almost never required. You should only use them if you have a specific problem.
    Jul 2010
    Ashland, KY
    21
    This is my neighbors pool. Water won't clear up. Took the top off for the first time. Pool 3 years old. Last year full of algae all the time. I have spent allot of time just killing the algae this time around. Allot of scum on top. Filter about 5/8 full. Looking for a easy way to change out sand and get the best filtration
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hope this helps. youtube can be your friend:
    http://www.youtube.com/watch?v=Ble6XX5mqe4
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    You can clean the sand bed by opening the filter and carefully inserting a garden hose down about 3" into the sand with the water running. Push it straight down and let it run a few minutes and pull it straight out again. Repeat the process all around the inside of the filter, being careful not to hit the laterals or the center stand pipe. Allow the dirty water to overflow out the opening. Feel around in the sand for clumps. Re-assemble the top and then backwash and rinse the filter as normal.
    Love TFP? Become a
    TFP Supporter!
