Results 1 to 9 of 9
Thread: Cloudy water
    Cloudy water
    I have tried everything to clear up this pool. It was even new water because I had to drain it to fix the liner. It turned soupy green, i cleared it up, turned green again. I went to the pool store they gave me stuff that killed the algae but it was still cloudy white. I have even changed the sand in the filter because it was old. I've been able to keep it from going green again, even though every time i test it there is no chlorine in it, but i still cant see the bottom through the white cloudiness. I've tried clarifier but that makes it all sink to the bottom and when i try to get it up, it just clouds up the water again. I dont know what the problem is, i've had this pool for 6 years and never had a problem.
    liner pool, i think its 12,000 gallons
    hayward sand filter and chlorinator
    use 3" tabs in the chlorinator and arm&hammer super washing soda for pH and alk
    the shock i just bought claims to have clarifier in it but it doesnt seem to
    Re: Cloudy water
    Welcome to TFP!
    First, you should post a complete set of water test results. They often contain clues to what is going on.
    Adding a little DE to your sand filter will often help it catch fine dust. Or, if you can get the dust to settle to the bottom you can get it up by vacuuming to waste really carefully and slowly so you don't stir it up again.
    Clarifier is very hit or miss, sometimes it works sometimes it doesn't.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy water
    Quote Originally Posted by thredhd
    even though every time i test it there is no chlorine in it......use 3" tabs in the chlorinator
    Welcome to TFP!
    If you let the chlorine get to zero, you are never going to get the water clear. It has to stay at an approriate level for your CYA, and if you use trichlor tablets your CYA is probably very high. The Chlorine CYA Chart will tell you what kind of level you need. You may need to supplement your chlorinator with a dose of unstabilized liquid chlorine or bleach several times a day to get it cleared.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Cloudy water
    Welcome to TFP!
    You have come to the right place to get some help.
    A couple suggestions for you.
    1: Read Pool School
    2: Get a good test kit (Taylor K-2006 or the TF TestKit-100)
    3: Post a set of your pool numbers.
    FC
    CC
    TC
    PH
    CH
    TA
    CYA
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Re: Cloudy water
    well thank you for your responses, i cant get any numbers for you right now, i dont have a good test kit and the pool store i use is closed until tuesday. but i do know the cya cannot be that high because on the 12th it tested at 25 ppm. i do have some test strips to give me an idea where i'm at. i added some soda ash this morning because the pH and alk were a bit low. i refilled the chlorinator because it was on its last tab. i added shock because the strip said i was almost 0 again. i backwashed really well because i've noticed the pressure climbing every few days since i changed that sand. and now i'm adding some DE. so i'll check back in, in a few days and let you know if its clearing or not.
    Re: Cloudy water
    well hot **** i can see the bottom of the pool! that DE stuff worked wonders. dont know how much chlorine is in it but its certainly pretty! thank you!
    will it start to cloud up again when it wants more DE?
    Re: Cloudy water
    The DE will last until you backwash. After you backwash you will need to add more. The pool should stay clear with or without additional DE as long as you maintain the FC level appropriately.
    Re: Cloudy water
    this pool is going to be the death of me yet! lol. i still cannot maintain chlorine and i cant figure out why. the chlorinator is full and on high. i got my water tested today, results below. the pH was a bit high but i got decreaser for that and the calcium was a bit low so i got some to fix that. but otherwise, there should be no reason for me to be at 0 chlorine.
    FC 0
    TC 0
    CC 0
    TA 90
    pH 8.2
    CH 120
    CYA 28
    Re: Cloudy water
    Your PH is too high. You need to get PH down to something more reasonable soon.
    You need to add a lot more chlorine to the pool until you can maintain an FC level overnight. That will be much easier to do if you get your own test kit.
