Thread: pH creeping up
    pH creeping up
    My pH keeps creeps creeping up, everything else is good. I am putting in 1/2 gal of acid every 2 weeks. Is this normal or is there another problem?
    30,000 gals, fiberglass, bleach
    30,000gal. IG pool - applied fiberglass over gunite when pool was remodeled, cartridge filter, 1HP pump, 100 gal/min flow rate
    Feb 2008
    Denton, TX
    5,061
    Re: pH creeping up
    What is your TA?
    Re: pH creeping up
    It is usually high TA, ie using too much baking soda, that causes PH to rise. Lowering TA will usually take care of it, unless you have a really large amount of aeration (large waterfall or negative edge).
    Re: pH creeping up
    CH is 220, TA is 70, I use bleach (6%) for chlorine
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: pH creeping up
    So if you want, you can let the TA drop a little more which it will do with your acid additions (i.e. don't raise the TA back up with any baking soda). If the amount of acid you need to add gets less and the rate of pH rise seems to slow down, then you can stay at the lower TA level if you want. Just so you know, half a gallon of acid every 2 weeks, which is 4 cups a week, isn't a lot for a 30,000 gallon pool, but if you're able to lower that by having the TA lower, then that's certainly fine to try. Let us know how it goes.
