Thread: spider gasket maybe?
    Dec 2009
    Columbia, SC
    34
    I have water leaking from my multi-port valve from the extra port that has a plug in it. Do I need to just replace the spider gasket or can you replace the plug maybe? if so how?
    Thanks!!
    18k gallon in ground plaster with attached spa
    Pentair CCP 320 cartridge filter
    Goldline Aqua Rite SWG
    IntelliFlo VS pump
    Teledyne Laars ESC heater
    Hayward Pool Vac Ultra cleaner w/ skimmer Vac Plate and inline leaf basket
    Palm Springs, CA
    22,551
    Re: spider gasket maybe?
    You can replace the plug but the correct way to fix it is to replace the spider gasket. Replacing the plug is just using a band-aid to cover up a bigger problem. The spider gasket is pretty easy to replace and you'll know the job is done right.
