- Jun 1, 2018
- 13,806
- Vinyl
- Hayward Aqua Rite (T-15)
Elevated cc’s are indicative of an organics problem-
But Just having low cc’s alone aren’t a confirmation that organics aren’t present -
This is why there are 3 end of slam criteria to be met before ending the SLAM Process & why that is just one of the criteria for passing the Overnight Chlorine Loss Test.
You’re in the Pool Owner Patience part.
Confirm your current cya level & keep maintaining the appropriate slam level fc as often as possible. FC/CYA Levels
The reason for brushing & or vacuuming daily is because algae forms biofilms to protect itself from chlorine- brushing/vacuuming breaks this up allowing the chlorine to go to work. You can do this blindly. Removing debris is important but not the only reason to brush/vac during slam.
Keep calm & SLAM ON!
