BryanR
Believe it or not, but Houston is freezing over for 5 straight days with a temp as low as 10 on Monday.
27000 gls. T-15 Cell with Omnilogic. I do not have freeze protection. Variable speed pump. Current pool temp is 49 degrees and outside temp is 34.
Issue is I'm already getting low temp alarm. I have a heater, and turned it on for 5 minutes and the alarm went away. I read above where I should not run the heater because they do not do well in cold temp.
This may sound ignorant, but should I wrap my t-cell with insulation? I have had to replace my cell 3 times and pool is only 5 years old. I'm a little hyper-sensitive in protecting them now. I plan on running my pump 24/7, at 50% to keep water flowing through pipes?
