2nd pump / sweep / jet
Danyo.lau
22
San Leandro, ca
I have a secondary pump can someone explain how it work?? See attach photo… should the valve be on or off? The pump is currently not on a timer and has to be turn on manually.
You're not using it. It is a Polaris Halcyon booster pump for a pressure-side cleaner. Your signature indicates you're using a Dolphin robotic. Can be removed or left in place.
Reactions: Danyo.lau
