Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Michigan Pool Build
    Newpool2011's Avatar
    Jan 2011
    Southwest, MI
    37
    Michigan Pool Build
    They got started this morning! We are really excited that the build has begun. I will keep adding photos.
    18x43x28, 32K gal, True L Vinyl IG
    DE Filter, 1.5 HP Pump, Heat Pump, IC40 SWG, Pentair Easytouch, Dolphin Supreme M4
    Jan 2011
    Southwest, MI
    37
    Re: Michigan Pool Build
    They set the walls yesterday afternoon.
    30,419
    VERY nice looking pool and great pics!! Please post more when you can....we all love pool builds.
    PS - tell your trees to GET BUSY and grow some leaves!! (just kidding, we redneck Southerners just can't resist)
    May 2011
    lebanon tn
    370
    yes, looking good!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jan 2011
    Southwest, MI
    37
    They poured the footings and concrete floor this morning.
    Jan 2011
    Southwest, MI
    37
    Steps are set and curing! They are measuring for the liner tomorrow.
    Apr 2010
    Portage, MI
    28
    Pfft. Duraleigh were lucky there isn't snow up here still. But the leaves are finally on the trees this week.
    Vinyl IG, 19k gal, Intelliflo Variable Speed, Hayward S244T Sand Filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    This is the first anti-gravity pool I have seen. How will water stay in? )
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Jan 2011
    Southwest, MI
    37
    Bench and steps are finished, waiting for the liner!
    Jan 2011
    Southwest, MI
    37
    The Dolphin M4 is ready. We are still waiting for the liner. Hopefully this week!!
    Jan 2011
    Southwest, MI
    37
    They did some grading yesterday and set up the equipment pad. The liner goes in as soon as it stops raining.
    Casey's Avatar
    SW PA
    10,441
    How very exciting! I'm getting my bikini ready so I can test it out for you and make sure it's all perfect!
    Jan 2011
    Southwest, MI
    37
    Filled it yesterday! Three truck loads.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    oh I am so jealous! All I have is a big hole in the ground the cats play in all day!
    Jan 2011
    Southwest, MI
    37
    It has rained all week! Not much getting done except for a little electrical. I can only run the pump 3 hours at a time to avoid overheating as it's temped up on 110. The water is getting more clear each day. I'm going to try out the test kit this afternoon. I did drop the Dolphin in last night for about 3 hours.
    Jan 2011
    Southwest, MI
    37
    Concrete was poured yesterday, waiting on electrical now!
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Nice pool I'm not sure I understand the overheating problem you are describing Care to elaborate?
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Jan 2011
    Southwest, MI
    37
    Thanks! I was referring to the pump overheating. The electrician has it temporarily running on 110 and said it can only run for a couple of hours or it will overheat and damage the pump motor.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Is the pump a 240 volt-only motor, or is it dual-voltage? If it's a 240-only motor, then that makes sense. If it's a dual-voltage motor, then it should be fine on 120v.
  20. Back To Top    #20
    Jan 2011
    Southwest, MI
    37
    Everything is up and running! Salt was added yesterday we are waiting to see if more if needed.
