Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: copper stain on new plaster
    Apr 2011
    League City, TX
    20
    just installed pool in September of 2010. Ran heater and now I have copper stains.
    AA treated a couple of times and removed some of the stains but now I am stuck. any suggestions.
    Its a chlorine pool with ozone generator.
    No help from installer........
    15500 gallon pool, white plaster, Jandy Flo Pro Pump model FHPM, Jandy Cartridge CL/CV Versa-Plumb series, DEL OZONE Eclipse ozone generator. KATCHAKID SAFETY NET, Baracuda G2 pool cleaner, Gas-Fired Pool & Spa Heater
    Re: copper stain on new plaster
    Welcome to TFP!
    Copper stains can be problematic. What color are they?
    Apr 2011
    League City, TX
    20
    they are brownish in color..... used jacks magic test kit for copper scaling and got positive result (#2 treatment)
    treated two times with suggested amount of what I am assuming is Absorbic acid.
    Brown is more likely to be iron. Have you had the water tested for copper and iron?
    Ozone is very good at oxidizing metals, which means that preventing stains is almost impossible when you have metals in the water and use an ozonator.
    What happened, why did the copper heat exchanger get damaged?
    Can you post a full set of test results?
    Can you provide a full profile of your pool? Pool type, size, equipment etc?
    Can you post some pictures?
    Support the site
    Apr 2011
    League City, TX
    20
    Ok, thanks
    15500 gallon, cartridge filter
    i always got normal results on testing the pool chemistry.
    maybe i didn't metal treat enough when i filled pool initially ? ?
    I will post pics....but give me a minute to find them
    copper vs Fe treat would be different ?
    What is your pool surface, vinyl, fiberglass or plaster?
    Support the site
    Apr 2011
    League City, TX
    20
    plaster
    Apr 2011
    League City, TX
    20
    im having trouble posting pics........will attempt again
    frustrating.....considering how new the plaster is.....
    Where is Anthony and Sylvan ? not much help from them. they don't seem to care.
    Are the stains rougher than the rest of the pool surface or about the same?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by pbrunet
    Use Photobucket.com - once you upload your pics to their site, copy the IMG code and paste it in your message here - and the pic will appear.
    Apr 2011
    League City, TX
    20
    thanks to those who have replied
    the stains are the same texture as the rest of the pool or atleast not noticeably different.
    My guess is that you haven't used enough AA, but it is very difficult to be sure. One way to test that theory is to hold a vitamin C tablet against a stained area that failed to come off last time for 30 seconds to a minute and see if it improves. If the vitamin C makes a significant difference, then you simply didn't use enough AA last time. But if it stays the same we will need to try something else.
    Apr 2011
    League City, TX
    20
    thanks jasonlion
    I was thinking along those lines as well........ doing a test spot......... but didn't think about using an actual Vitamin C tablet. I will try this today.
    Was also thinking about a concentrated amount of HCl at a shallow spot like a step.
    I noticed at the pool store a brush with steel bristles vs vinyl bristles like I am currently using. I just don't think it is something that will brush out.
    Metal stains don't brush off. You can grind them off, but that damages the underlying plaster.
    Apr 2011
    League City, TX
    20
    OK,, so i tried the Vit C tablets and it actually left a new stain where i left the tablets. Strange....... but i also checked the pH and its probably too high right now (8.2) . The stain left by the Vit C is almost purple on one stain and more dark brown on another stain.
    not giving up hope...but clearly there was a reaction to the Vit C.
    Yea, copper can do that. It changes oxidation levels and the color changes. Some oxidation levels are easier to remove than others. Try treating a small area with some dry acid wrapped up in a sock or stocking and see if that helps.
    11,969
    That and get that PH level down.
    Apr 2011
    League City, TX
    20
    Thanks
    by dry acid are you saying Absorbic Acid. ?
    No, dry acid is sodium bisulfate, sold in pool stores as PH Down.
  20. Back To Top    #20
    Apr 2011
    League City, TX
    20
    OK, so all the areas that i treated with AA yesterday are now clean and white. Surprise!
    In concentrated spots it actually cleans up the stains...... probably removing some of the plaster.
    Todays test with Dry Ash also has a positive affect. Again though it feels like it may be taking a layer of plaster in the test spot.
