Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 97
Thread: Newbie, first opening
    Nov 2010
    South Central Kentucky
    283
    Okay. Had a neighbor help get me started. He's had a pool for several years.
    Where I'm at now.
    Cover is off. Pool vacuumed. About to backwash after the vacuum. Since I'm opening should I test before shocking or just go ahead and add some bags of shock? Water level is good if that matters.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Newbie, first opening
    Always test first! Be sure and test the CYA level. If it is above 50 and you do not have a saltwater chlorine generator then you do not want to use a dichlore/trichlore shock product. Dichlore/trichlore with add CYA to the pool. Once you have too much CYA the only way to get rid of it for most people is to partially drain and refill the pool.
    Liquid chlorine, either 6% regular bleach or 10-12% strength from the pool store is the best for chlorinating or shocking the pool without added excessive CYA or Calcium to the water.
    Love TFP? Become a
    TFP Supporter!
    The first thing to do is to run the pump for an hour and then test the water to see where you are at.
    If the water is clear, free of CC, and no obvious problems turn up there isn't any reason to shock.
    Similar to what zea3 said
    Nov 2010
    283
    It is an SWG pool. I have the TF100 test kit but I've never done it. Will test tonight and see what I need to do.
    Nov 2010
    283
    Pump has been running for at least an hour. Water is a bit cloudy. I can see the bottom though.
    Nov 2010
    283
    Currently trying the FC and CC tests. Water is not turning pink when I add R-0870. What does that mean?
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    you have no chlorine. Add some bleach. Suggest putting more information on your pool into your signature so people can help you with your water chemistry. ie...size of pool, equipment, filter type, pump size, features.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Nov 2010
    283
    Solution also stays clear on the CYA test. Could see the dot all the way to the top of the test tube.
    Ph did show up at 7.2. That's the only result that has looked like the test said it would.
    Nov 2010
    283
    I've updated my sig with what I know. I don't have the gallon amount.
    Nov 2010
    283
    So at this point should I dump in a couple bags of shock? Turn on the SWG? Put in bleach?
    Quote Originally Posted by joshs2000ss
    Your pool is going to be about 14,400 gallons (15 X 32 X 4 (average depth)).
    Start off by adding 6 quarts of bleach (regular, 6 % sodium hypochlorite) and retest after a few hours to see what you get on the FC and CC tests.
    Support the site
    Jan 2010
    Central Valley, CA
    233
    have you read pool school, particularly that shock is a process not a product? If your CYA is zero, you will be ok with the bags but the trick is maintaining FC at the right level until CC is less than .5 and bleach or liquid chlorine. You do need to get CYA to 30 for best shock so dichlor or trichlor will help initially.
    Keep posting your tests and listen to the mods and you'll be on your way to a trouble free pool.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Nov 2010
    283
    I did read through pool school. Will read again tonight. Since I apparently have little to no chlorine, I'm just trying to figure out the best place to start. According to the calculator I just need to add some bleach to get the FC levels up. I'm going to read some more and try to find my way a little better. Just a bit overwhelming at this point and I don't want to let it get away from me by not doing something.
    Nov 2010
    283
    I will get bleach tomorrow and add then retest. Thanks for helping me in my troubled state.
    Nov 2010
    283
    I'm guessing at this point that I don't turn on the SWG until I get the levels where they need to be?
    Nov 2010
    283
    Also. Should I turn the pump off for now or leave it running until I get the bleach in there?
    Jul 2010
    Pt. Arthur, TX
    174
    Keep the pump running 24/7 until you pass the overnight/cc test.
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
    Nov 2010
    283
    Added the recommended bleach. 182 oz bottle to be exact. Checking levels 5 hours after adding and so far here's what I've got.
    FC - .5
    CC - 2
    CYA - 0
    TA - 80
    CH - 180
    At what point in this process do I need to turn on the SWG? It is currently off.
    I will note that we've been getting heavy rain off an on since I removed the cover. I'm beginning to wonder if I need to drain off some water.
    Jul 2009
    Houston, Texas
    9,429
    You should go ahead and add CYA to the pool. If you already have bags of dichlore/trichlore you may use those. If you do not have them you can buy CYA at the pool store or some Walmarts will have it as well. Add enough to bring the CYA to 30 ppm for now. Once you have completed shocking the pool you can bring the CYA up to 70 and turn on the SWG.
    I have some additional questions for you. What does the water look like now, clear or cloudy? Do you have a vinyl liner or a plaster surface in the pool? Do you have test results for pH?
    You want to keep the water level in the pool 1/2 to 3/4 the way up the skimmer opening. If the water is higher than that then you may want to drain it down a little.
    Love TFP? Become a
    TFP Supporter!
  20. Back To Top    #20
    Nov 2010
    283
    Pool is constructed with a vinyl liner, I will add that info to my signature. Currently the water is a bit cloudy. I can see the bottom easily (and a few spots I need to hit again with the vacuum after the lightning stops )
    According to the calculator, I need to add 60 oz (by volume of stabilizer) so I'm reading that as a little over 3.5 bags of the granular chlorine shock, but it says this will also lower the pH, which as of last night was already down to 7.2. Do I just need to point my returns toward the surface to aerate and bring that up a bit? I will re-test pH also, because I haven't checked it since adding the bleach.
