Thread: New owner which kit?
    Oct 2010
    Eastern TN
    172
    I've been studying the pool school and posts. My pb has chemistry parameters that don't square with pool school's. I get a free ph kit with pool. Would the tf100 or smaller kit with a bottle of larger cya test reagent be best?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Jan 2010
    Central Valley, CA
    233
    Re: New owner which kit?
    most builder's and all pool stores aren't going to comply with BBB. Go with the TF100 and don't look back. I got advice from my seller (AGP) and the result was $150 of chem's still sitting in my garage.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Tf100 Unless the PH kit is a Taylor Phenol Red Drop test, if it is you can get the TF50
