Results 1 to 11 of 11
Thread: CYA Tests are they all the same???
    Kannapolis, NC
    89
    Seen a tester where the dot was on the stick, as well as a tester where the dot was on bottom. Just curious???
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: CYA Tests are they all the same???
    I doubt it makes much difference. It's just measuring how much cloudy water it takes to hide the dot.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    22,551
    The stick tests are very inaccurate. The black dot test is much better even as hard as it is to do.
    Jan 2009
    Cupertino, CA
    1,966
    If you meant test strips, yes. I think Bowlin was referring to a view tube where you pour in the whole mixture, and the black dot is on a slider that you move up and down. I've not used one of those but offhand I'd guess they work about as well as the kind where you add mixture until the dot on the bottom disappears. They might even be easier to use; certainly easier to rerun the test if the dot's on a slider.
    --paulr
    BBB "Intermediate Swimmer"
    Personally, I would appreciate a test that didn't rely on my increasingly faulty vision. I'm never sure if I'm seeing the dot disappear or not.
    22,000 gallon, 34' X 24' freeform Pebble Tec pool and raised 7' spa with spillway, SWG, Jandy Stealth pump, natural gas heater, cartridge filter, Jandy LED colored pool lights, Jandy electronic water leveler, Polaris 280 pool cleaner
    Aug 2007
    near the swamp
    806
    we use the tube with the dot on a slider
    22,551
    I was thinking of the strips. but, yeah the sliding dot would be about the same accuracy as the dot in the bottom.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    If you're talking about this one:
    it's the Blue Devil CYA Test Kit from Valterra Products. I have it saved on my Amazon.com wishlist priced at $19.99 selling from Discount Pool Mart, but they want $9.49 shipping. For some reason I can't seem to pull it up in a search today on Amazon. You might be able to order it from your local pool store for about $25-$30 as well, or maybe find it cheaper elsewhere online.
    The Porpoise CYA Test Kit looks very similar and sells for only $11.99
    I used the Blue Devil tester at my local Leslie's and I find it much easier to read accurately than the one that came with the Taylor K2006 kit.
    I've got one on order, should be in next week.
    Hope this helps,
    Gary
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    Aug 2007
    near the swamp
    806
    the latter is what we use
    The CYA tests with the slider are a little easier to use. The tube is larger and you can fiddle with the slider up and down very easily to get a more exact reading without re-pouring. However, that style does use dramatically more reagent each time. Taylor also makes one in that style.
    Kannapolis, NC
    89
    exactly what I was looking for thanks all
    _________________
    My Pool:
