Results 1 to 17 of 17
Thread: Our Pool Started Feb 28th Idaho
    This is our first Pool. We are excited to get it finished.
    21,500 Gunite Free Form ~ 18'X40', Sun Deck w/ foam jets auto valve, 3-Laminar Deck Jets w/ auto Valve, 1-Swim out, 3' to 8' deep, NPT Raku Tile
    All Sched 80 Pipe, Pentair Easy Touch control, Pentair pump and Sand Filter, Raypack Heater, White Plaster, Saline Chlorine Generation, Letro Platinum cleaner w/ booster
    Re: Our Pool Started Feb 28th Idaho
    Rebar pics
    22,553
    Is that snow I see??? Brrrrrr! welcome to TFP.
    Yes. It has been a wet Spring. Snowing on the day they excavated. Thanks this is a great site with lots of info.
    Gunite
    Tile and all underground piping done. Also attached Pool companies Landscape Architect plan
    I am curious what others are using for Pool Backwash? Company said that worst case could be 70 gpm for 5 minutes. Thats 350 gallons! They originally had this approved with the building dept. to go on the lawn. I can't imagine 350 gallons of diluted chlorine water doing any good for our lawn. I designed this dry well to handle 400 gallons and had them pipe to it and I picked up with Sch 40 pipe to the barrels. Total cost for this was about 70 bucks when i include the 30 dollars they charged to dig the hole.
    Apr 2010
    Buckeye, AZ 85326
    619
    Looks awesome. What will you do with the water that is in the dry sump? A lot of my friends backwash straight into thier lawns with no adverse side effects. I've drained a few inches here and there and put the water onto my lawn with no issues. Keep the photos coming !
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    The bottoms are cut out of the barrels along with lots of slots in the sides. I dug down until I hit a sand layer and I perc tested it to drain. It dropped about 1 in a minute and its damp soil because of the spring. So summer it should drain off well. Thanks for the compliment.
    Photo Update.
    Pool water is good for the lawn unless you are in a very wet or swampy area. The chlorine and other pool chemicals don't bother anything except the most sensitive plants and just about any lawn grows better with more water. Of course, there is nothing wrong with setting up a dry well if you want to.
    Updated pic, can not wait to get yard back into shape.
    July 9th. Finally starting to get the yard in shape. Still have more trees to plant. The pool has had a slight leak from the day they filled it. They have drained in twice. Once to go over all penetrations again, pressure test again, reseal lights, etc. The second time since that didnt work they drained it to apply a product called Akron. Still didnt work, same rate of leak. About 2 inches in 24 hours. I think it is a crappy plaster job installed on a rainy day. At least the PB is really actively working to resolve it. Next step is to let it leak until it stops. Hopefully the PB will step up and replaster if need be. Has anyone had a similar problem?
    Update on leak. I counted numerous posts that didnt have an update or solution to problems people had, so I thought I better update mine. It turns out, it was the electrician. He did not use the rubber cord/grounding water stop in the light niche. He just packed it with buytl tape. Once they fixed that, it has held water. We can finally say we have a completed pool. We got the salt added, I have to say I really like the salt water pool. I will post pics of pump pad area when I get a chance hopefully this week sometime.
    22,553
    Thanks for posting back.
    You're right, a lot of the time we give advice and never hear whether it helped or not.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Great job, looks aweasome
    Here are the pump pad pics I promised. Thanks for a great site. I look forward to using the BBB method to keep the water crystal clear.
