Thread: EcoStar VS and Intermatic Timer
    Apr 2011
    Fresno, California
    46
    Hi Guys,
    New owner of an old pool. Just bought EcoStar VS after some research on this site. I will install it myself. Any heads up will be helpful and appreciated. On question I have is that I have the same Intermatic Timer as in the above picture and Heater and pump are on the same load screws ( #2 # 4). I know I have to connect the pump to #1 and #3. But can I leave the gas heater on the same timer on #2/#4. ?
    Split off of this topic. JasonLion
    23k IG. Plaster. StaRite system 3 Cartridge Filter (S7M120), Pentair MiniMaxNT Heater. IntelliFlo VS (8 Speed). Going BBB
    Re: EcoStar VS and Intermatic Timer
    Yes, you can leave the heater controlled by the Intermatic timer while wiring the EcoStar directly to power on #1 & #3.
    You want to be careful to program the timers so that the heater is never on when the pump is off.
    Apr 2011
    Fresno, California
    46
    Thanks Jason. I am waiting for IntelliFlo VS 8 speed (New). Hook up should be same.
