Results 1 to 8 of 8
Thread: Slippery concrete
    Jan 2011
    Roseville, CA
    18
    Slippery concrete
    I have stained, stamped concrete around my pool. It LOOKS nice, but unfortunately slippery when wet. Any ideas to keep the look but reduce the slip hazard?
    30,415
    Re: Slippery concrete
    Good morning,
    You can Google "anti-slip" products and get LOTS of products. How effective they are, how long they will last, and how much they will alter the look of the concrete is a hard question.
    Perhaps you have one out-of-the-way area where you could experiment before applying something to the entire deck.
    22,548
    On stained stamped concrete my only suggestion would be a clear coating with glass beads in it. That way you'd still have the color and pattern and the glass beads would produce a sparkling effect when the light hits them just right and provide a little slip resistance.
    Apr 2011
    Denham Springs, La
    4
    Clearcoat with sand. I painted my patio with epoxy and applied the clearcoat with sand mixed in and it works fairly well. Home Depot/Lowes sells the clearcoat and sand. Good luck.
    Bryan
    33000 gallon vinyl salt water
    Polaris AutoClear chlorine generator
    Sand filter
    I'm going to second the clear coat with sand. I did that to my garage floor and it really helps. The roll on stuff isn't too much (about $60/gallon) and two gallons covered my whole 12 x 20 garage. You could probably do your pool deck with 2-3 times that.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    I have tried 2 different products for this and while they helped some, the deck is still very slippery. Don't put on too much, it'll start to show white-ish on a darker deck. Sand may work... maybe I'll try that next time. My folks had a similar stamped deck put in but did not have it bi-colored or sealed. It really looks nice and is not slippery at all. If I get tired of it being slippery I might just have it sandblasted down to the concrete and live with just the base concrete color (intregal color).
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    May 2009
    Topeka, KS
    81
    I put some 'quickcrete' anti slip additive in the paint I used for my coving. it worked great and was really cheap.
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    Sherwin Williams carry a product call "Shark grip" it is a synthetic grip to be used in paint and clear coats. it works great, is transparent so it wont show white like sand, and when mixed it is lighter than sand so it stays in suspension after it is mixed in, and does not all fall the bottom.
    17,000 gallon IG Humpback Kidney
    333k Sta-Rite Max-e-therm Heater
    Sta-Rite Modular Filter
    Intellichlor IC-40
    Awesome Tiki Bar!!!!!
