Results 1 to 13 of 13
Thread: parts for liquidator
    Oct 2007
    south carolina
    17
    any one know where to buy replacement parts for the liquidator?
    Dennis
    Dennis
    22,550
    Re: parts for liquidator
    Call Hasa and ask them.
    www.poolandspawarehouse.com has them too. You have to search the site for them, but Paul (all your parts) has them.
    What parts are you needing?
    Oct 2007
    south carolina
    17
    I need a tube adapter
    Dennis
    Dennis
    22,550
    Are you talking about the tubing nut the screws onto the float valve?
    Take a picture of the part you need and I may be able to tell you where to get one.
    Oct 2007
    south carolina
    17
    A tube adapter is the small black plastic part about 11/2 inches long that goes through the inlet and outlet PVC pipes to and from the pool it is held in place by the stainless steel hose clamp and has a small rubber washer on the bottom side to prevent leaks. The top of this part which the tubing connects to is made of rather thin plastic which tends to break, thus I need a new one.
    Dennis
    Dennis
    Feb 2008
    Denton, TX
    5,061
    22,550
    Contact Hasa or Paul (all your parts) but in the mean time I'll look around the shop to see if I can find my left over ones. I threaded my piping and use threaded to adapters for the connnections so I never used the clamped fittings.
    257 beat me to it! That's exactly what you need.
    Oct 2007
    south carolina
    17
    A treaded fitting sounds interesting, is it stronger? Maybe you could describe that option more fully as it may be a better solution to my problem.
    Dennis
    Dennis
    22,550
    Basically you just get a threaded adapter (I use 1/4" MNPT to 3/8 push-in tubing) and drill and tap the PVC pipe to accept it and hook the hose up. Yes it's magnatudes stronger than the clamped type and a lot cheaper too. You could also use threaded to barbed fittings.
    Here's the fitting I use. Your original LQ tubing will slip right in it. I used them everywhere and even changed the check valve out to a 3/8" size.
    Oct 2007
    south carolina
    17
    Thanks for the info bought a fitting for $2.00 taped the PVC and it is up and running. Much stronger than the original. Great idea.
    Dennis
    Dennis
    Dec 2010
    San Diego, CA
    1,137
    What do you use to tap the PVC with?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    22,550
    A regular 1/4" NPT tap. I have a set of taps but you can buy them at any of the big box home improvement stores.
    Dec 2010
    San Diego, CA
    1,137
    Thanks Bama!
