Thread: Please help me select a pump
    I am about to install a 21'X41' X 54" oval AGP. I am sinking, but not back filling, pool. I need a self priming, 2 speed agp pump that will work with my size pool and a 22" sand filter. I plan on placing the pump and filter about 30'-40' from pool. Thanks in advance.
    21' x 41' Oval AGP for all 9 kids and wife 1 Skimmer, 2 returns, 22" sand filter, Pentair Dynapro 1.5 HP 2 speed pump.
    22,551
    Re: Please help me select a pump
    How far are you lowering the pool? All the way to the top rail?
    If the water line is above the pump suction even a little you don't need a self priming pump.
    The filter and pump will be above or right at the water line. I am not done leveling the hole yet, so I am not positive on the water height compared to pump. I would rather be safe and get the self priming pump now instead of finding out later that I need one.
    Thanks.
    Perhaps something like the Pentair Dynamo 3/4 HP two speed, DYNII-N2-3/4 HP, or the 1 HP two speed, DYNII-N2 1 HP. These are both medium head pump that are capable of priming relatively small distances above water level (a couple of feet).
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,402
    You may want to consider a larger filter. According to The Pool Calculator the volume of your pool will be around 25,700 gallons. You may want to look at a 1 hp 2 speed pump and the largest sand filter that will fit your budget. A larger filter will go longer between cleanings and provide better filtration than a small filter with a big pump.
    Are you planning to add any other features to the pool, such as solar panels, heaters, salt water chlorine generators, ect?
    Love TFP? Become a
    TFP Supporter!
    I might be adding a SWG next year, but not sure yet. I also am planning some water features in the future (slide, fountain, etc.)
