Thread: tips and procedures for fixing a standard pool light...
    Apr 2010
    Southern California
    83
    Does anyone know of some good articles, threads, or better yet, online videos about fixing a pool light? Thanks!
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Re: tips and procedures for fixing a standard pool light...
    There are many videos at YouTube.
    Nov 2009
    Katy, TX
    94
    I have the original documentation that came with my pool lights. Pretty straightforward procedure. Will try to scan and post this week.
    Inground with 7x7 spa (spillover)
    20k gal plaster (sunstone)
    pentair 3/4 hp (filter), 1 hp (spa), 1/2 hp (features)
    cartridge filter
    SWCG IC-40
    Polaris Platinum (with booster)
    Apr 2010
    Southern California
    83
    Thanks!
    Mar 2007
    Coastalish 'down easter'
    4,160
    What kind of fix are we talking about?
    Luv& Luk
    -Ted
    Apr 2010
    Southern California
    83
    Pretty standard fixture and the same as the ones in most of the videos I watched on Youtube, it takes a 400w floodlight.
    So far I detached it, removed the lens and replaced the bulb and gasket, but it still doesn't work. I checked voltage inside the light head and got nothing with the light switch on. Checked voltage at the back side of the pool light switch and got 34 volts (weird!), while the adjacent light switch (it's a double switch) that turns on flood lights that are mounts around the outside of the pool wall is showing 120 volts at the connections on the back of the switch.
    Not sure what to do next. I really don't know how you can have only 34 volts. Usually you either have full voltage or nothing, not something in between...
