Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
Thread: Another DIY Build
    Another DIY Build
    New to the site, great information here. I am finishing up the dig and am needing some help with the plumbing layout. The plumbing will all be behind the walls and not ran through the pool FYI. My question is are the Skimmers and pool returns in a good location, and to make equal pressure for the deck jets and pool returns should I do a loop system like I have shown. All plumbing will be with Rigid 2'' PVC.
    I am sure this has been discussed before but there are way to many links on here to go through.
    After I iron this out I will need some help on the best way to tie this all together at the pad. Thanks in advance for all the input that I hopefully will receive.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    2 HP Hayward Super Pump with 25" Sand Filter Filled with Zeo Bright
    4 Pentair Deck Jets
    2 Hayward ColorLogic 4.0 Lights
    Diving Board
    Turbo Twister Slide
    Hayward Aqua Plus Automation with 2 Actuators
    100% DIY Build not 1 penny paid yet to build this thing!!!! = Lots of work and Long Nights
    Re: Another DIY Build
    Another thing is I figure the total gallons is around 37000. The pool is 44x32. Shallow end is 20Wx32Lx3.5D and the deep end is 24Lx20Wx6 deep average with slope.
    My question is do I have enough returns for the pool and what size pump should I use. The place I got the pool from sent me a 2hp hayward super pump. Should I try to get something different and would a 2 speed pump benefit me, less power consumption would be nice.
    I will have 4 deck jets and a Turbo Twister water slide that need water also. Would I be better suited to go with 2 pumps in this situation? I am using a robotic cleaner so I dont have to worry about running a Polaris.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    It's hard to tell from the diagram (but, thanks for it!) but you may want to put a return on the same side as the 2 skimmers and break the pool into 2 zones, each covered by 1 of the skimmers.
    That looks like a 'Mt. Lake' liner pool. Where would you have the steps? Having a return on the second step, pointing the same direction as the 'flow' in the shallow end is what I'd suggest.
    I'll leave it to those who know better than I to suggest pump sizing
    We're here to help you and appreciate updates as you come closer to sealing the deal.
    Luv& Luk
    -Ted
    I updated the picture to show the location of the steps. The blue arrows pointing into the pool are the returns.
    I added some pictures of the 60 bags of vermiculite. The start of the pool dig process. We have a little water table issue and had to put in a drain system to draw the water out.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    By breaking the pool into 2 areas will 3 returns work ok or should I have 4?
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Quote Originally Posted by allybuck64
    It will work, but i always like 2 returns per skimmer, plus step jets when there are walk in steps
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Based on the location of my skimmer (Red box) were would the best locations be for the returns be?
    Thanks for the advice.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    If I go with 4 returns and 2 step returns should I plumb them all together or make it to seperate return lines.
    One for deep end and one for shallow end and steps.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Mar 2007
    4,160
    Hi again.
    While I'm a fan of more returns, given your setup, 3 should be fine and a fourth would mess up the flow. If you add another return on the 8' reverse radius panel between the 2 skimmers, you'll set up a clockwise flow in the shallow end and a counterclockwise flow in the deep end.
    A second stair return would help keep the treads cleaner. Run 2 return lines from the pad, 1 for the 2 opposite (from the skimmers) side returns and the other to feed the stairs and central return. Connect the 2 return lines with a 3-way valve for 'fine tuning' the flow and, should that not be enough, you can always play with the size of the directional inlets (eyeballs).
    Please remember to plumb the returns parallel not in series! If you need any help with the plumbing lay out, there are some GREAT guys here that can assist you
    Luv& Luk
    -Ted
    Ok stay with 3 returns and stair returns. Thanks alot. Any guys on here you recommend me that I can PM?
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Lots of progress made will post pics later today. Couple questions. I need to raise the shallow end 2 inches to bring it level what's best to use #56, crusher run, sand or dirt that was pulled out. What about out of those for backfill material, I have read #56 but that's going to cost me over 1000$ were sand will be about 1/3 of that. If I go with sand I would put in a french drain to move water away from pool walls. Any advice please.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    South Central NJ
    3,192
    Don't use the dirt you pulled. Sand or 3/8 gravel are much better bets as they won't settle or form voids.
    Scott
    Owner of - PoolGuyNJ LLC
    Scott, thanks for the reply. Sand costs around $10 a ton were as gravel costs $35. Is gravel going to be worth the extra cost involved. I will need alot of backfill around 50 tons. So there is over $1000 difference!
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    30,421
    It's interesting that quarry materials pricing seems to vary a lot around the country. Here in NC, sand and rock are pretty close together.
    That said, I don't like sand as a fill. It "washes out" very easily and doesn't have the same "porosity" as clean rock. Crusher run wouldn't drain very well, either. I would use rock/gravel despite the cost.
    Are you sure about the 50 ton calculation? That's about 900 or so cubic feet (I think) and seems like a lot for that size pool.
    I did the math at 3 foot over dig the parimeter of the pool is 130 ft and needs to come up 3 ft. I forgot to subtract bond beam so it will be less but not by much. What about crusher. Run to raise shallow end 2 inches to bring it to grade.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    30,421
    I'm too lazy to re-read the thread.......are you planning on a vermiculite bottom?
    Yes I plan on using vermiculite.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Dec 2009
    Central Massachusetts
    2,690
    I wouldnt use pure stone. Best stuff to use is processed gravel. You might call it "bank gravel", "1 inch minus", etc. Compacts well and drains well.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Lots of progress made this week will post pics today. My question is about the pool hopper walls. In a couple areas they got over dug to much. Since its such a large slope what is the best way to build them back to the proper dimensions.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
  20. Back To Top    #20
    Bond Beam all poured. Worked on plumbing this weekend and will finish monday afternoon. Then pressure test and backfill. Deep end with 2 ft of 3/4 inch to help drain the water to the pump.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
