Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Brian & Dorie, Phoenix
    Feb 2011
    Metro Phoenix
    17
    Hello to all from sunny, central Phoenix!
    Middle aged, empty nester, first time poolers here. We've a lot to learn, but we are soooo excited about finally being able to swim whenever we want .
    Brian & Dorie
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Brian & Dorie, Phoenix
    Welcome to TFP!
    22,548
    Welcome Brian & Dorie.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Welcome to TFP!!!
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome!
    I suggest you start by reading Pool School - the link's on the upper right of every page. And get a decent test kit - they're discussed in Pool School, too. Order one right now, and get a speedstir at the same time, because where you live, you'll be doing the CH test a lot, and your wrists will give out. The real key to a troublefree pool is regular, consistent, accurate testing and dosing. And for that, you need your own test kit.
    And besides, the first time you ask a question, the first response will be "Can you post a full set of test results?"
    Guest
    Welcome....
    Apr 2010
    Buckeye, AZ 85326
    619
    Welcome! I'm in AZ as well...a little more west. Out in the Buckeye area. Read pool school and then just skim the board for general helpfull info that will save you tons of time and money.....good times!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome to TFP
    Feb 2011
    Metro Phoenix
    17
    Thanks for the warm welcome everyone!
    I've a couple things today;
    First, the water analysis the store did
    FAC: 5
    PH: 7.6
    TA: 120
    CYA: 200
    TDS: 2700
    I was advised by the local store to drain half the pool and re-fill. I've got the pool half emptied and will re-fill after I've got the bottom vacuumed (I've got almost all of the debris out of it).
    In the mean time, I need to order a testing kit AND we're looking for a used automated vacuum.
    We found this on our local CL:
    Used Polaris 280 $200
    I asked:
    Can you proivde more details on the pool cleaner, please? How old is it, any repairs done recently, any receipts for parts/ repairs? Also, I'm reading on line that this model may need a booster pump, did you have to do that with yours?
    The response:
    not the 280/ in very good condition/ no repairs/ less than 2 yrs if intersted please call for pick up thank you
    What do you think, both about the water and the vacuum? I had considered the Hayward pool vac but there's so many mixed reviews. We're really at a loss as to which way to go on the vac.
    Thanks again!
    B&D
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    30,419
    The Polaris 280 seems to be a great machine. It's a pressure side cleaner requiring a booster pump....do you have the booster installed?
    Draining half your water is a great start. You need to get the CYA down around 50 to make things all work well so test again after you refill from this drain and be prepared to drain half again if your CYA is 100 or so.
    22,548
    There's only one caveat to those numbers. The pool stores are notoriously wrong especially when testing CYA. You did good by draining half but I suggest ordering a TF-100 test kit and a speedstir and do your own testing before you do too much else. It'll give you a good starting point and we can help get it in line once we have good numbers to go by.
    Feb 2011
    Metro Phoenix
    17
    I've no booster pump, just the single pool pump. I guess I'm off to see what a booster pump costs...
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    Feb 2011
    Metro Phoenix
    17
    Thanks Bama, a good test kit is on the short list of things to get done now.
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by B&D
    Is a suction side cleaner not an option?
    2' Powerfall
    Feb 2011
    Metro Phoenix
    17
    I just bought a used Hayward off of CL. I hope the guy was honest...
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    Feb 2011
    Metro Phoenix
    17
    I'm going to order the TF100 kit and speedstir later this evening. All that's left now, I think, is the pool cover and a hand net.
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
    Apr 2010
    Buckeye, AZ 85326
    619
    Dont forget to post some pics of your pool...we would love to see it!
    2' Powerfall
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Feb 2011
    Metro Phoenix
    17
    Ok, just ordered the TF100 test kit. I also bought replacement sand as I noted debris and plant particulates on the sands surface.
    After draining half the pool and re-filling several days ago, running the pump and pool vac for several days and keeping the pool covered after re-filling, todays water sample is as follows:
    FAC: 5+
    TAC: 5+
    PH: 7.8
    TA: 210
    CYA: 100+
    TDS: 2500-3000
    The store associate said to again drain half the pool and re-fill. At this point I've decided to leave the water as it is, change the sand and perform the tests myself once the kit arrives. We're very much wanting to go the BBB route of water maintenance and, as much as possible, stay away from as many other chemicals as possible.
    Thanks in advance for your thoughts.
    Brian & Dorie
    Brian & Dorie
    7500 Gal
    Hayward Sand Filter
    In Ground
    Hayward 3/4 HP pump
  20. Back To Top    #20
    Apr 2010
    Buckeye, AZ 85326
    619
    Good call. CYA over 100 is manageable although not optimal for the BBB method. As long as no CYA is being introduced to the water it will slowly drop to optimal levels due to dliution.
    Still waiting on those pics
    2' Powerfall
