Results 1 to 13 of 13
Thread: Pump stays on although off with Aqua Link
    Hello - I have an Aqua Link RS8 installed apx Oct03. My filter pump is set to come on at night and turn off before I am up in the morning. On a few occassions over the past several months, the filter pump would still be on in the morning. I would go to the control panel near the equipment, put in 'service' mode, and press the the normal filter pump button a few times. The light would turn on and off accordingly but the pump would not, like it is stuck in the "ON" position. I then decided to go to my breaker panel on the first occassion and flip the breaker controling the control panel. This worked and have done the past few times this has happened. Now, the same issue is happening and I can not get it to shut off unless I flip the individual filter pump breaker in the control panel. My thought something it up with the relay. Has anyone experienced this problem or can point me in the right direction on resolving? Thanks in advance!
    Re: Pump stays on although off with Aqua Link
    Welcome to TFP!
    It might be the relay, but given that it is winter, is it possible that the pump remains running on days when it is especially cold out? I suspect you are seeing freeze protection coming on, which keeps the pump running when the system thinks there is a chance of freezing.
    Thanks for the welcome and for your reply. No, llive in the Phoenix area, and although it does get below freezing on a few occassions which causes the freeze protect to come on, we have had gorgeous weather lately... no where near freezing. Bright and in the 70s this afternoon and still have this issue. Maybe the relay?
    Jan 2010
    Spring Texas
    47
    I am getting same problem. My temp readings say the pewter is 28 in Houston in October? I have a jandy aqua link2 and screen says freeze protection enabled. How do I disable this feature or what di I need to change to correct.
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Jan 2010
    Spring Texas
    47
    Ok I got a new handy 7786 temp sensor that has a black wire and a red wire and when I go to replace old sensor it had 4 wires (red green black white) going into the aqua link 2 control. Is this going to work? And
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    rdeputy,
    The four wires you see are probably the comm wire for the remote in your house, or the SWCG. Wires are attached to a red buss?
    Look to the right and you should see a couple of sets of two wire connections, all red and blk. They should be marked: water, air, and solar, not ness. in that order.
    Factory Warranty Station for:
    See pic
    [attachment=0:2rrb2wx4]AquaLink-Sensors.JPG[/attachment:2rrb2wx4]
    Jan 2010
    Spring Texas
    47
    Ok thanks guys. I will give it a try
    Mar 2011
    441
    Quote Originally Posted by rdeputy
    If you have a bad 4 wire temp sensor you need to replace it with a 4 wire temp sensor.
    Put it in service mode, if the pump stays on, smack the control box with a fist. If the pump shuts off you need to replace the relay.
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by racket
    4 wire temp sensor? On an RS8?
    Mar 2011
    441
    Quote Originally Posted by Pool Clown
    RS8,no aqualink 2 yes.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Ahh, Thanks for the correction. Can you still get parts for those?
    Quote Originally Posted by racket View Post
    Years later (now 2014, the original post was in 2010) I found this really helpful. Thanks racket!
    Now I need to find out how to replace the relay. Great for now just to be able to turn it off, since no button anywhere was working to shut the pump off.
