- Apr 11, 2019
- 40
- Plaster
- Hayward Aqua Rite (T-9)
Hello!
My aqua rite SWG is around 20 months old. Within the last 30 days, the salt reading has started to show artificially low on the SWG.
I cleaned the unit (diluted acid bath), with no change in behavior. So I took it to a pool shop and they tested it on a Hayward tester unit, and it passed.
So now I’m I’m confused. It’s acting like the cell has gone bad, but it passed the test. Any tips on what’s going on here?
Stats:
Salt: reading 2300 pppm, actual 3400.
volts: 27.3 (same if I turn off and back on to flip polarity)
Amps: 3.6
Pool: 10k gallons
Cell: t9
Water Temp: 80 degrees
Usual percentage: 25%
On the unit, low salt and check cell are flashing.
If the board has gone bad, I would expect it to no recognize the cell or not generate chlorine. It is generating chlorine, but it’s reading wrong and the volts are too high.
What could be going on here? Thanks!
Stats:
Amps: 3.6
Pool: 10k gallons
Cell: t9
