Thread: Magnapool system
    Magnapool system
    Hi has anyone any experience with the "Magnapool" Potassium/magnesium salt based water traetment system. Australian in origin I believe. Lots of hype and marketing but I am wondering about actual performance.
    thanks
    Rayna
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Magnapool system
    Hi Rayna,
    I had never heard of the Magnapool, but after a brief perusal of their website I can offer the following opinion: it may work, but you can get similar or better performance with less money and goofy pseudo-scientific language.
    It sounds like it's a salt-water chlorine generator that uses potassium and magnesium chloride instead of sodium chloride. Without knowing more details than their website offers, it's not possible to know if their system produces enough chlorine to sufficiently sanitize the pool. The verbage about it being more ecologically responsible and balancing its own water is bunk.
    Adding magnesium chloride to your pool water is a bad idea. It is much more likely to cause damage to decking and coping than ordinary salt is. Potassium chloride is fine; it's just much more expensive.
    I would say stick with a normal SWG, which will be much cheaper and is a tried-and-true technology. Straight and to the point, without all the eco-beauty-homeopathic babble.
    Yes I think you are probably right. A good vehicle for selling you a new pump, filter etc.
    thanks Rayna
    It appears that the Magnapool system is a marketing scam for a salt chlorinator with no independent data to back up claims. Check out the following link for comments from the inventor http://forums.whirlpool.net.au/archive/1529192
