Results 1 to 8 of 8
Thread: Inground Pool with Above Ground Return Line
    X-PertPool's Avatar
    Exeter, PA
    1,385
    This pool is in need of a new liner and a prior pool guy replaced a damaged return line and used an above ground wall fitting. The problem is when you go to change a liner in an above ground you can unscrew the large nut on the back of the assembly (which is now buried) to remove it to install a new liner. You can see how this is a problem now that you can no longer access the nut buried under concrete.
    How would you go about making this work for a new liner?
    I have a few ideas of my own, but would definitely like to hear some suggestions or ideas.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Gulf Coast, AL
    61
    Re: Inground Pool with Above Ground Return Line
    how was he even able to screw that wall fitting in?
    16x32 Grecian, vinyl liner, IG, 19000 gal.
    1.5 h.p. Hayward Super Pump 2 speed. Hayward S244T sand filter
    Circupool RJ45 SWG, TF100
    30,432
    Hi, Kevin,
    That's a big hassle!!
    1. Eliminate the return by destroying from the face side of the pool and plugging it with epoxy and installing new liner over it.
    2. Dig it up from the back and put a correct one in. That would be one big job as it obviously is too high as well and, of course, you can never match the concrete.
    I see no really clever solutions.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    I am assuming the eye screws into the fitting. Could you perhaps remove the eye and using pvc glue on the threads, screw and glue in a length of pvc long enough to grasp easily with a large vise grip and unscrew the fitting that way?
    Love TFP? Become a
    TFP Supporter!
    South Central NJ
    3,192
    If the deck is less than 4' wide, tunnel under. More than 4', tunnel with shorings(vertical 2x4s) set every 3' or so. Replace the bulkhead fitting with the correct one. It really is the only way to do it right,
    Scott
    Owner of - PoolGuyNJ LLC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by soundguy
    All the other lines in the pool are dead and plugged up. This return line was a replacement (you can't see the repaired concrete area to well in the photo)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    30,432
    If there is already some repaired concrete near there, then it makes more sense probably to remove ALL the repaired concrete and fix the return properly.
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    I would use an internal pipe wrench to grab the internals so you can remove the pool side fittings. Here is what they look like, it uses a cammed toothed wheel that is offset so that when it is rotated it grabs the pipe from inside. Most tool supply stores or lumber supply stores that sell plumbing supplies have them.
    I use them primarily to remove broken short nipples from equipment I repair, very handy tool to have in the tool box...beware there are cheap china made versions out there that are OK for plastic pipe but not so great for steel or stainless pipe.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
