I stopped by Home Depot and couldn't find a single adapter but I found two and got it connected.
This is unfortunate. I didn't realize this when I bought the gauge. I read your message and watched the gauge and it swings by a lot. I really just wanted a gauge I could read without bending down. And preferably one that doesn't need venting before reading if the temp changes.The only problem with having your gauge laying back like that is that the pressure relief port isn’t on the top, so when you open it to vent the gauge oil may leak out. Because of the way liquid filled gauges work they are very temperature sensitive and if you don’t vent it before you take a reading the pressure may vary by as much as 1 or 2 PSI between the morning when it’s cool and in the shade and the afternoon when it’s hot and in the sun.
Time to look at McMaster I suppose.
Try it with a few anxious kids waiting like its Christmas morning. With an audience things never go smoothly and all you'll want to do is loud cursing but you can't because kids.but the cover is such a pain.
They're held on by zip ties high enough on the legs where the ties won't touch the pool wall, I was worried about chafing and wearing a hole over time.How did you attach the PVC holder to the pool?
Also, doesn't the oversize cover trap rain and then make it difficult to remove?
Just in time for an over the top and incredibly detailed closing post, stuffed full of pics, right ?The swimming season has come to a close here in Wisconsin I believe
Looking forward to that too. Will likely take down my Intex AGP here in Minnesota to store it for winter - but would like to do a bit more 'permanent' install next year and see if I can leave it up over the winter. With all the work @jseyfert3 put in, I'm guessing he's not taking it down...Just in time for an over the top and incredibly detailed closing post, stuffed full of pics, right ?
That is correct, I am not planning on taking it down. I do need to start thinking about the winterization process though.With all the work @jseyfert3 put in, I'm guessing he's not taking it down...
It. Never. Ends. LolBeing a homeowner with lots of projects means I'm never not busy
