Results 1 to 8 of 8
Thread: SWG Cell Life
    SWG Cell Life
    Hello,
    Wondering what the impact on Cell Life is based on the fact that I run my pump on Low Speed almost 24 per day?
    Thanks.
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Oct 2007
    Valrico, FL
    542
    Re: SWG Cell Life
    Probably none. Life of a cell is really measured in amp-hours. Amp-hours for a given cell cooresponds to a certain amount of chlorine produced. So for any given pool, you will usually have a fixed chlorine demand, which remains the same whether the chlorine is added all at once, or over a complete day. Therefore the amp-hours used will remain the same.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Re: SWG Cell Life
    This is our answer in our pool store, there might be a better one comming up.
    The speed of the pump is of little impact on cell life, as long as your cell don't produce while the pump is off, that is. What's important is how much chlorine you demand it to produce and if your cell is undersized for your pool.
    - Avoid starting your pool in the spring using your SWCG (if applicable).
    - Use CYA (there is a chart stickied in the Pool School on what amount you should target).
    - Keep an eye on your water chemistry. SWCG tend to make your pH rise a lot.
    - Avoid having ''too much'' salt in your pool. Go with the manufacturer's recommendation.
    - Check your cell once a while for deposits. (once or twice a year should do the trick)
    This is often written on this site:
    - You might have an easier time with the addition of Borates. You WILL NOT need less acid BUT you will need to add it less often.
    - Avoid ''Shocking'' using your SWCG.
    Pool: None, and All.
    ''What's really interesting is finding some way to explain some technical concepts with simple terms so that everyone might understand, to vulgarize.'' CaOCL2
    Jul 2007
    Brisbane, Australia
    874
    Re: SWG Cell Life
    cell should be alright, but you might find that controller won't last as long as it normally would
    Re: SWG Cell Life
    Quote Originally Posted by Strannik
    Curious as to why this would be.
    I ran my variable speed pump for the last 9 months at about 2100rpm. Before that I had a one speed 1hp pump.
    I just replaced the cell literally today after just under three years of use - 34 months at 600 bucks this give me a pretty decent 17.64 cent per month cost. Next time Ill put in a "generic cell" and clean it more frequently.
    I have a 20K pool and use a 40K salt cell turned down to about 40% with about 8-85 degree water temps.
    So I'm using the double sized/half output technique.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Jul 2007
    Brisbane, Australia
    874
    Re: SWG Cell Life
    because electronic components also have their lifespan
    if your controller runs 24/7 - that lifespan is shortened
    the technique you are talking about assumes that you will be running same number of hours as with smaller cell, just at lower output
    Re: SWG Cell Life
    ahh.. I see where you are coming from and agreed.
    - yes in that all electronics have a lifespan yes you may them bump up against the controllers if running 24/7.
    I was thinking there may be some other link you were making.
    Of note: at least in my personal experiences, many electronics fail on "power up" rather than die during a running cycle.
    Some machine rooms in my industry simply never power down, others do.
    Depends on the CE's preferences.
    thanks,
    Uncle Dave
    Jul 2007
    Brisbane, Australia
    874
    Re: SWG Cell Life
    it's true that they fail mostly on power up, that's because of the current in rush. so new component might handle it with no problems, but old and tired one will pack up.
