Thread: preping filter for closing
    Jul 2010
    col. Ohio
    15
    I'm getting ready to close the pool and was wondering should i take the Valve of the filter for the winter? the filter is new and I dont want to ruin it by having freezing water damage it.
    10,000 gal. above grnd.
    300 # sand filter
    solar cover(do not use often)
    22,553
    Re: preping filter for closing
    We really need to know more to accurately give advice but if it's a multiport valve, there should be a winterize setting that basically opens all the flow paths and allows it to drain completely through the bottom drain of the filter. For extra assurance I'd blow the entire system out with it set to winterize just to make sure.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If it's a multiport you can remove the slight glass,o-ring and also the pressure gauge.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
