Thread: Return Splitter
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Return Splitter
    Hi All,
    Does anyone know if there is a product to split the flow of a return jet into two (or three) different directions?
    There is a circulation "dead zone" in my pool I am trying to resolve.
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Jul 2009
    Olney, MD
    218
    Re: Return Splitter
    If you unscrew your eyeball and replace it with a threaded PVC fitting, the options from the plumbing section of Home Depot are endless. I did so and now my deep end return goes an extra two feet down. I have also constructed an aerator as described in several threads.
    Be careful you keep everything pointed in the same general direction so you don't mess up the direction of your surface circulation to your skimmers.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
